Transmission & Drivetrain Gearboxes, Differentials, Clutches
1999 Acura Tl 99-2003
Old 06-01-2011, 09:00 AM
avargas07's Avatar
Default 1999 Acura Tl 99-2003
I have a 99 acura tl 3.2 vtec none type S and the transmission needs to be replaced. I am alittle confused because mine is a 4 speed and the 2000-2003 come 5 speed. Wondering if a 99 acura tl 3.2 vtec tranny type S will work on my none type S and will it function. Also found a 2001 acura tl 3.2 vtec none type S wondering if that one will work? Please need the help ..
Old 06-01-2011, 10:46 AM
Seagull Management
94EG8's Avatar
Default Re: 1999 Acura Tl 99-2003
Synchro-tech can tell you for sure but I doubt it, it'll probably bolt up just fine but I wouldn't be at all suprised if the gear ratios are different (if they are you will have shifting issues and the PCM will throw transmission codes) 5 speed TL trannys definitely wont work.
Btw, if I were you I'd look into a rebuild, those transmissions were known to be junk, expect a used one to fail sooner or later as well.
avargas07
Acura TL, RL & ZDX
05-30-2011 07:12 AM
Turbodude06
Acura TL, RL & ZDX
11
03-07-2010 05:26 PM
raviee
Acura TL, RL & ZDX
03-27-2008 11:03 AM
Quick Reply: 1999 Acura Tl 99-2003
