Ok..how is this for weird...I changed my oil type and...
Old 02-07-2002, 06:45 AM
HX_Guy's Avatar
Default Ok..how is this for weird...I changed my oil type and...
My oil pressure went up! WTF?!
If you guys remember, after my engine rebuild my oil pressure dropped from 72 @ 3000 to 66 PSI, anddropped another 5 PSI when I went VTEC. The only thing different was the oil type, I used to use Mobil 1 with the stock B20Z and have been using regulat after the rebuild.
Well 3000 miles has passed and I switched back to synthetic last night...and my oil pressure went up! It was at around 60-61 PSI @ 3000 with regular oil and now its at 66-67 PSI!
Old 02-07-2002, 06:48 AM
speedymon's Avatar
Default Re: Ok..how is this for weird...I changed my oil type and... (HX_Guy)
That's where my pressure is at. 65psi @3k rpm. I have a 96 GSR.
Old 02-07-2002, 06:58 AM
ZygSpeed's Avatar
Default Re: Ok..how is this for weird...I changed my oil type and... (speedymon)
Very interesting!
How was the oil filter...
Thicker (more pressure), better!?
Old 02-07-2002, 07:07 AM
HX_Guy's Avatar
Default Re: Ok..how is this for weird...I changed my oil type and... (zygspeed)
Oil filter was good...its been only 1000 miles since last change.
Ive changed te oil many times since the rebuild, and every time it was 60 PSI @ 3000,,and now 67 PSI. Oh well, cant complain..Ill keep an eye on it.
Old 02-07-2002, 07:09 AM
b00st-0wnz's Avatar
Location: Drinking Beer in sunny FL and jamming to Skid Row, USA
Yep, Synth does build oil pressure in my experience as well. I still use regular oil though cause I'm not worried about the 5-6psi differnece i've seen in my cars with it.
Old 02-07-2002, 07:20 AM
Fillmore Slim's Avatar
What weight oil do you guys use Ive been using 5w30 synthetic but have been noticing the engines making alot of noise..I might need to adjust the valves possibly
Old 02-07-2002, 07:22 AM
HX_Guy's Avatar
Default Re: Ok..how is this for weird...I changed my oil type and... (JDRB16A2)
Im using 10W30
Old 02-07-2002, 07:24 AM
New User
nsxtcjr's Avatar
Why are you people with other cars posting here? This is supposed to be the Integra Type R forum - for talking about the Integra Type R. If you want to talk about technical aspects of other cars, move it to the Tech forum.
Old 02-07-2002, 07:26 AM
HX_Guy's Avatar
Default Re: Ok..how is this for weird...I changed my oil type and... (nsxtcjr)
Im using an Integra Type R oil pump...
...do I have your permission now?
Old 02-07-2002, 07:28 AM
Johnny Tran's Avatar
cause he can, and rolls trye arrrs........there, now i linked it to type r crap, post away hxguy
Old 02-07-2002, 07:29 AM
Global Moderator
Reid's Avatar
Honestly if this was about a GSR with I/H/E, I'd agree it needs to be moved, but HX_Guy and others (Tony the Tiger, Lip, etc.) with a relatively large amount of work done to a DOHC VTEC B series motor provide us ITR owners with useful info.
Old 02-07-2002, 07:30 AM
Willard's Avatar
Will
[Modified by Willard, 11:31 AM 2/7/2002]
Old 02-07-2002, 07:55 AM
I find that i Get better info from the type R Forum ..Id rather be involved in forums that discuss Mods that are functional not Body kits and NOS But Going foward Ill take My little civic talk Elswhere ...Sorry to waste your time
Old 02-07-2002, 11:28 AM
Mike K's Avatar
val.. you should use an RSX oil filter. i saw 5psi increase at every rpm, over the OEM one.
B HATCH
04-14-2005 08:44 PM
hondapwr
03-11-2004 02:43 PM
vtec.dc2
03-09-2004 04:41 AM
brainwo
08-07-2002 12:50 PM
HX_Guy
12-05-2001 02:49 PM
Quick Reply: Ok..how is this for weird...I changed my oil type and...
