Sqeaking on front end=ball joint?
Old 03-31-2012, 05:27 PM
Ci-v-iC's Avatar
Default Sqeaking on front end=ball joint?
I could've never guessed that it may be it. Squeaking on driver side front end which I thought was dry bushings/moisture related. Fixed w/spray lube on bushings at the arms (not ball joint).
Next thing, lower ball joint snapped in two...looked sheared right in the middle to me???
There was no play so I think it's the ball joint material stress failure.
BTW, it's '00 Civic AT D7y16 and only 130 000 k/ 70 000 miles on it.
Can anybody confirm the squeak is symptomatic with ball joint snapping???
Old 03-31-2012, 05:34 PM
pm4nudes
chewyv's Avatar
Default Re: Sqeaking on front end=ball joint?
Ball joints can sqeak when they're toast. Might as well inspect all of the ball joints. Replace with moog if you can. Their product uses stronger material.
Old 03-31-2012, 05:39 PM
Ci-v-iC's Avatar
Well, a lesson learned about the squeak but there is no play in the opposite side and there is no squeak there yet...how else can one determine they're toast then?
BTW, I did replace with moog + put in a new axle since the old one popped out splitting the boot closer to tranny.
Old 03-31-2012, 06:27 PM
pm4nudes
chewyv's Avatar
Those are the only methods I know. Sqeak and play. If the boots aren't torn and everything else checks out, you should be good.
geartex
01-08-2018 06:46 AM
89efhatchcrap
Suspension & Brakes
24
02-17-2009 10:36 AM
DEL HATCH
12-16-2006 01:57 PM
ultraforce77
07-15-2004 02:59 PM
Vp Special K
17
01-06-2004 02:08 PM
Quick Reply: Sqeaking on front end=ball joint?
