What is the Spark Plug for B18C?
Old 12-02-2002, 12:07 PM
New User
volkracing99's Avatar
Default What is the Spark Plug for B18C?
What spark plug do I have to buy for B18C engine.
And what is the GAP?
Where I can get it.
Thanks
[Modified by volkracing99, 2:14 PM 12/2/2002]
Old 12-02-2002, 04:57 PM
myhatchrips's Avatar
Default Re: What is the Spark Plug for B18C? (volkracing99)
ngk #bkr7e-n11
or
bosch #4227 both are a 7 plug
Old 12-02-2002, 05:09 PM
Kataku2K3's Avatar
Default Re: What is the Spark Plug for B18C? (myhatchrips)
You use a seven? for a stock B18C i would go with a six or so.... Just what i use tho on a relatively stock motor....
Old 12-02-2002, 07:27 PM
New User
Default Re: What is the Spark Plug for B18C? (JDMspecEG6)
YUp that what I heard too...
Do you know what is the gap?
Old 12-04-2002, 04:18 PM
.044 is the gap i have slightly higher comp so i use a 7. a type r even uses a 7
Old 12-04-2002, 07:07 PM
andrewasf77's Avatar
type r uses a 6
Old 12-04-2002, 11:41 PM
96dc2's Avatar
Default Re: What is the Spark Plug for B18C? (andrewasf77)
stock plugs for c1 is pfr6g-13 and c5 is pfr6g-11. isn't it on a sticker under your hood? excuse the ignorance, but i always read about people with heavily modded motors running the bkr7e. just curious, can someone quickly explain the reasoning behind this? thanks.
Old 12-05-2002, 02:08 AM
New User
Default Re: What is the Spark Plug for B18C? (96dc2)
Someone told me that the bkr7e is colder spark plug and its good for turbo or SC, but not really good for all motor...
Old 12-05-2002, 03:51 PM
96dc2's Avatar
cool thanks.
Old 12-08-2002, 07:40 AM
the colder plug helps combat detonation at high rpms. only those pushing 185 + to the wheels should use the 7.
Old 12-08-2002, 07:23 PM
lsvtecvx's Avatar
I run the Bosch 4227 on my ls/vtec, isnt .044 gap alil too much considering its a plat. plug, I mean .044 is what they recommend on a copper plug
[Modified by lsvtecvx, 4:25 AM 12/9/2002]
Old 12-09-2002, 03:48 PM
mugenracer's Avatar
Default Re: What is the Spark Plug for B18C? (lsvtecvx)
The sticker on the cam belt cover on my jdm integra SiVTEC says BKR 6E -N11 (11 being a 1.1mm gap which is 0.04330696inchs)
Old 12-09-2002, 08:14 PM
In The Garage
Shawn C's Avatar
Default Re: What is the Spark Plug for B18C? (mugenracer)
yeah i run a bkr7e, but a basically stock engine i would run a 6
Old 12-11-2002, 03:14 PM
JPX
JPX's Avatar
NGK V power zfr6f-11
or
Denso Iridium power
IK22's
Pep boys of A utozone
Old 12-12-2002, 04:35 PM
well i run bosch 4227 and i dont set the gap because of the fact that its a platinum plug that is supposedly pre-gapped at the factory. but for ngk bkr7en11 i had them at .044 where should they be set at for high comp engines?
Old 03-20-2006, 10:07 PM
standinghollow's Avatar
are these plugs you mention go for jdm b18c's too?
cOvI3L
02-07-2011 05:58 PM
thielkedelsol
05-17-2006 12:57 PM
ej8slim
03-20-2006 10:16 PM
TypeR 599
09-04-2002 11:13 PM
Quick Reply: What is the Spark Plug for B18C?
