What gas do I use to pass smog?
Old 07-07-2010, 07:10 AM
acmoc's Avatar
Default What gas do I use to pass smog?
So I have to pass smog again.
I'm thinking of ways that might help
I always fill up with shell, should I use Premium or just the regular stuff?
I know it runs a little quieter on the mid grade stuff but it just might be me.
What do you guys suggest?
Thanks
Old 07-07-2010, 07:57 AM
redef90si's Avatar
Default Re: What gas do I use to pass smog?
Supreme, go take your car on the freeway for 15-20 to heat up your catilittic converter before you go to Smog,goodluck.
Old 07-07-2010, 11:39 AM
gator88's Avatar
Do you guys actually understand what octane helps with and what the cons are of running it?
Old 07-07-2010, 11:48 AM
TunerN00b's Avatar
Thanks
The octane that your engine was tuned for would be best for a smog check.
Higher octane means more resistance to ignition, and you want all of the fuel to burn as easily as possible for a smog test. In addition, most premium fuels have detergents and such to clean out the fuel system, and the last thing you want is any of that gunk being burned during a smog test.
That means regular low grade on a stock engine.
And consider a bottle of
or
Old 07-07-2010, 12:16 PM
thesmogman's Avatar
Us smog tech's recommend what the manufacture suggests. So Regular it is.
Remember if you run cleaners, such as injector cleaner, run it completely out of the system.
Old 07-08-2010, 07:42 AM
acmoc's Avatar
Yea, I bought regular. I never saw that bottle up top though
Old 07-08-2010, 08:17 AM
EL Vap133's Avatar
Listen to this guy, he knows what he is talking about.
Old 07-08-2010, 09:00 AM
I tell doctors what to do
ILcrxsi1's Avatar
Originally Posted by redef90si
Supreme.
I saw the thread title and came in here to make fun of the idiots in this thread that were sure to give this as an answer. Stop giving advice on **** you don't understand retard.
Old 07-08-2010, 09:08 AM
raceACCORDingly's Avatar
I concur
Old 07-08-2010, 10:21 AM
Scott_Tucker's Avatar
It's not really going to matter which grade of gasoline you use if your engine is running properly.
Its post like these that are making Honda-Tech a shitty place to get advice, that's just uncalled for. Especially since you didn't even give any reasons why your opinion might be right.
Old 07-08-2010, 10:34 AM
lostchild's Avatar
not sure if it'll make much of a diff, but i'll throw it out there. i hear stories where you can try E-85 with slightly bigger injectors...440cc injectors are what i've heard to maintain performance and get better emissions.
Old 07-08-2010, 11:55 AM
TunerN00b's Avatar
One would need to retune for E85, before it will run right.
E85 needs more fuel for the same amount of air.
Though, I suppose an engine running rich could be leaned out with some E85 added to the tank, the challenge would be getting the mixture right to not run lean, which raises NOx pollution.
Old 07-08-2010, 12:09 PM
Pumpking.'s Avatar
+1 on the heet in the gas tank
Old 07-09-2010, 09:29 AM
acmoc's Avatar
I heard of that too
Not sure why supreme would be better. doesn't it just have more cleaner
Old 07-09-2010, 01:40 PM
DCFIVER's Avatar
Iso heet works.
Old 07-09-2010, 11:49 PM
pm4nudes
chewyv's Avatar
Your gonna need BP gasoline.
Old 07-16-2010, 01:16 PM
acmoc's Avatar
I failed =[
All numbers too high, everything else was good
The guy id I have an air leak
too much or too little fuel in the combustion chamber but too much raw gas out the muffler
That crc stuff works?
Old 07-16-2010, 02:37 PM
DCFIVER's Avatar
I failed =[
Not for that.
Old 07-16-2010, 09:27 PM
pm4nudes
chewyv's Avatar
I failed =[
time to bribe.
Old 07-17-2010, 08:29 PM
You need to post the numbers for some help. Any additive you try adding to the tank is not going to work. There is something fundamentally wrong with your engine.
Old 07-18-2010, 12:08 PM
Hella_Reno's Avatar
How should I use this heet stuff? Cuz it says it treats 20 gallons of gas but I'm guessing I won't want it that diluted to pass smog right?
Old 07-18-2010, 12:10 PM
Hella_Reno's Avatar
Ps I have a 94 gsr motor so what octane fuel should I run it with
Old 07-19-2010, 07:40 AM
acmoc's Avatar
Buy regular, all gas in the U.S. is the same octane
I'll post my umbers later
My timing was 19 TDC
The tech told me I have an air leak and too much built up carbon in my engine
I have a sohc zc with dc sport header AEM CAI and tanabe medalion exhaust.
Car is a 91 crx
I set the timing on the cam gear back two degrees, so I assume now it's at 17 TDC
I checked my fuel pressure and it's at 42-43 psi
I had changed my oil and poured some engine restore in, had 400 miles on it so far
I know my IACV is going out so I cleaned it real good before the test
Old 07-19-2010, 07:43 AM
acmoc's Avatar
What does the iso heet do?
Do I run it through or run it in the tank during the test?
Old 07-19-2010, 10:35 PM
Hella_Reno's Avatar
Yeah I'm wondering the same thing, and how much fuel should I add it too? Cuz it says 20 gallons but I don't have a 20 gallon tank obviously and I know it's not intended for passing smog, so should I add it to like a half tank or 1/4 or what?
Quick Reply: What gas do I use to pass smog?
