TWM ITB TPS QUESTIONs
Old 06-04-2004, 07:31 PM
baxter04's Avatar
Default TWM ITB TPS QUESTIONs
1. Is the TWM TPS compatible with the stock ECU? If yes,
2. How do you wire the TWM TPS to work with the stock ECU?
Thanks.
Old 06-04-2004, 09:37 PM
Kal
Kal's Avatar
Default Re: TWM ITB TPS QUESTIONs (baxter04)
what ecu? most ITBs require standalones.
Old 06-04-2004, 10:02 PM
baxter04's Avatar
Default Re: TWM ITB TPS QUESTIONs (Kal)
P28
Old 06-04-2004, 10:38 PM
Kal
Kal's Avatar
yep, you'll need a standalone.
Old 06-04-2004, 11:23 PM
RedZone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">yep, you'll need a standalone.</TD></TR></TABLE>
Where did you get this info from?
You can use the TWM tps with any ecu as long as you wire it correctly. Use the connector from a SAAB wiring harness, they use the same TPS sensor. then all you have to do is wire it up. if you like i can go through my binder and find the wireing pin outs and post it up for you, or you can come by the shop and get it....you are near me.
Old 06-04-2004, 11:52 PM
baxter04's Avatar
Default Re: TWM ITB TPS QUESTIONs (RedZone)
Thank you so much for your info. I would greatly appreciate if you can post the wiring pin-outs.
Harrymonk
06-21-2018 11:25 AM
chevellion
11-12-2010 09:25 PM
blu3g
12
07-26-2006 11:17 AM
sammydigital
02-21-2006 03:19 PM
HondaCutter
09-13-2002 02:49 PM
Quick Reply: TWM ITB TPS QUESTIONs
