idle loping
Old 07-25-2002, 02:54 PM
New User
GruvyTune's Avatar
Default idle loping
hey.
engine is running fine after the rebuild. i get a funny loping thing going on at idle. i get a pretty good and steady idle at most times dead on at 750 then other times i get a loping up and down kind of rhythmic up and down 100 or so rpm. i have not yet fine tuned the hondata but i'm running open loop on my original fuel maps. wideband showing maybe just a tad rich.
I see my tps reads about .53 V (about 2-3%). its always read about that anyways and never caused a problem. other peoples cars i have tuned i have seen anywhere from 0.46 to 0.55.
any ideas? vacuum is good, no signs of leaking.
torin
Old 07-25-2002, 03:09 PM
Spade's Avatar
Default Re: idle loping (GruvyTune)
Stock cam??? If not, it's probably your cam.
Old 07-25-2002, 05:10 PM
New User
GruvyTune's Avatar
Default Re: idle loping (Spade)
no, stock cams just new pistons, rods and headgasket/studs. had new valve seals put in too.
any ideas about what can cause a funny idle loping like that? I get no cel and the hondata has a green light and hondalogger shows nothing suspicious.
Old 07-26-2002, 08:17 PM
New User
GruvyTune's Avatar
seems like it was my tps. i never changed its position before but somehow my new built engine is sensitive to the voltage there being off a bit. voltage was 0.55. i wacked it with a hammer a few times to move it and got it to 0.49 and that seems to have solved the surging idle.
B20EF
04-21-2009 10:51 AM
99b18
11-11-2004 05:36 AM
Brian_92GSR
05-31-2004 03:57 PM
slimbo
05-16-2004 10:57 PM
GruvyTune
07-25-2002 07:38 PM
Quick Reply: idle loping
