Old 03-25-2015, 12:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Lighting
Print Wikipost
tail light stays on
Old 01-21-2011, 08:42 AM
enemy no1's Avatar
Default tail light stays on
I have an issue with one of the tail lights on my 97' integra. The light stays on even when the car is off. Anyone have any idea why?
Old 01-21-2011, 11:16 AM
fcm
Old Fart
fcm's Avatar
Default Re: tail light stays on
Are you sure it is a tail light and not a turn signal or brake light? 94
Old 01-21-2011, 11:17 AM
enemy no1's Avatar
Its a tail light/brake light and yes I'm sure.
Old 01-22-2011, 07:47 AM
fcm
Old Fart
fcm's Avatar
Umm, which is it, brake light or tail light???
The brake light and tail light, [park light] are two different filaments of the same bulb, [dual filament bulb].
How about the rest of the lights at the rear, tail lights, brake lights, signal lights, back up and licence plate lights, are they all working properly.
The only light circuit that has power at all times, [ign. switch off] is the brake light and park light circuit, the brake and park light circuits are common for left and right, which makes me wonder why only one of the possible four lights are on. 94
Old 01-22-2011, 07:50 AM
BLK2DOOR's Avatar
make sure the rubber bumper didnt fall off the brake pedal that contacts the senor that cuts the light off happen on my car.
Old 01-22-2011, 08:57 AM
bruno8747's Avatar
Check the brake light switch, Its the one above the brake pedal. They normally go bad and either leave the lights on or not at all.
Old 01-22-2011, 02:00 PM
enemy no1's Avatar
I will check into this and let you know.
Old 01-22-2011, 02:11 PM
enemy no1's Avatar
ok i think its the brake lights. I checked the other light and the filamanet is burned out and I tested the light socket with a new bulb and it works so I'm actually experiencing the same problem with both sides. I put a bulb in and the light comes on automatically. Also the back up lights are not working either.
Old 01-22-2011, 02:13 PM
enemy no1's Avatar
Thanks for the tip. I'll check into this tomorrow when I have more light. If the switch is bad do I have to order one from the dealer or is this something I can get from the auto parts store?
Old 01-22-2011, 02:15 PM
enemy no1's Avatar
I'll check this tomorrow also thanks.
Old 01-22-2011, 02:35 PM
fcm
Old Fart
fcm's Avatar
Most likely the brake light switch pin stopper has fallen out, [broken] or brake light switch needs adjusting, [adjusted too far back].94
Old 01-22-2011, 05:10 PM
enemy no1's Avatar
Thats what Im thinking. The car sat for a while and I had the same problem with the clutch pedal switch. (the rubber grommet thing fell out) So I'm assuming the same thing probably happened to the rubber grommet thing on the brake pedal. Thanks for your help. I'll let all of your know what I find out tomorrow after I look at it.
Old 01-23-2011, 06:25 AM
enemy no1's Avatar
The rubber grommet fell out. That was the problem. Thanks for all the help everyone
Old 02-17-2014, 04:31 PM
myoungs82's Avatar
FYI, there is also a rubber grommet on the clutch pedal that often breaks and makes it impossible to start your car. For that, and for this, I simply use a small round magnet. I read about it here as a temporary fix, but I've continued to use them as a permanent fix. The first time, on the clutch switch, the magnet slid and I had to redo it. But once I got it centered correctly, it's worked for several months now.
Regarding the brake switch and grommet. Someone told me a few days ago that my backup lights didn't come on. When putting the magnet on the brake pedal for my tail lights tonight, I noticed another switch on the clutch pedal that seemed to be missing a grommet. I've put on a magnet to see if that's what controls the backup lights.
David Bromberg
10-02-2012 09:41 AM
tgun08
04-01-2008 07:28 AM
raffydogg
03-21-2008 06:32 PM
thn116
08-12-2007 07:14 PM
luvmyhonda
08-21-2004 03:35 PM
Quick Reply: tail light stays on
