SRS light ON
SRS light ON
Hello all,
I have passed thru some flood water, and as a result. my SRS lights wont go OFF.
i did the SRS reset proceedure, and it still lights.
i checked the 10AMP fuse, and it was blown, replaced and did srs reset again.
still wont go off.....
is there a way to pull the CODE to see whats causing the problem?
thanks guys
thanks guys
Re: SRS light ON (b16a4)
only way to retreive the srs code is either to goto a dealership or if you can find someone with a badass snap on scanner that can pull the code. You will probably have to end up replacing the SRS unit.
deanwashere
07-25-2018 04:28 AM
villaninblack
05-20-2009 10:08 PM
