sputter at high rpm and no power
Old 07-29-2014, 05:41 PM
ch22ris's Avatar
Default sputter at high rpm and no power
Alright guys so I'm having some issues with my 91 civic. I got this car from a guy that said he had an lsv in it and it now have the d15b2. Anyways the car runs and drives but it feels like it has no power at all. It has the same power at 1/4 throttle as WOT. Also once you get up into higher rpms it will start to sputter and backfire, the actual rpm I don't know I don't have a tach. Also I can pull out the two spark plug wires closest to the cam gear and the idle will not budge, but if I pull out the two closest to the dizzy the idles will drop. The wires are firing I can pull them out and see the spark when grounding a spark plug. I have been searching and trying to replace parts to find the problem but nothing has been solved yet.
What has been done so far
Distributor
Timing belt
Fuel filter
Spark plugs
Head gasket
Any help would be awesome! Thanks in advance guys!
ch22ris
07-29-2014 06:39 PM
spitfiremk2497
10-03-2008 10:56 AM
killaj12
08-14-2005 12:28 AM
Speedz
09-10-2002 06:06 PM
Quick Reply: sputter at high rpm and no power
