Removing bolt from cam gear
What's the easiest way to do this? I normally do it by taking the whole cam with the cam gear attached to it and remove the bolt by holding the pulley in the vice.
Re: Removing bolt from cam gear (Lyonel)
Some cams have a spot where you can use a open ended wrench to hold the cam in position while you break the bolt loose. You can also put a screw driver in a opening of the cam gear so it binds with the cylinder head and break the bolt loose.
Re: Removing bolt from cam gear (Mac8008)
OrangeBoost
13
04-25-2006 06:50 PM
