Problems calibrating tps on gsr
Old 01-08-2014, 01:05 PM
JdmRex805's Avatar
Default Problems calibrating tps on gsr
I have ek with gsr swap. I changed it from obd1 to obd2a and added skunk2 intake manifold. Car ran fine when it was obd1. Now i get cel 7 and have a high idle. Figured must have bumped the tps when swapping out manifolds. I did the calibration procedures but I am getting 5.06V at closed throttle and 5.03V at wide open? When i turn the tps I get no change. Already replaced the tps with one from autozone and it does the same thing? Any ideas what it can be?
Old 01-08-2014, 01:28 PM
n/a2boost's Avatar
Default Re: Problems calibrating tps on gsr
are you testing the middle wire of the tps plug with the meter grounded to chassis?
Old 01-08-2014, 01:38 PM
JdmRex805's Avatar
Positive on the middle red wire and neg on batterry ground.
Old 01-08-2014, 01:57 PM
I'm really 2slow
2fast4u831's Avatar
Did you use a hopper? what did you change to make it obd2a? most likely a problem with the wiring or hopper.
Old 01-08-2014, 02:08 PM
JdmRex805's Avatar
No. I had a jumper harness when it was obd1, car still has obd2a wiring so just plugged it in to the obd2a ecu. Only added ckf sensor and secondary o2
Old 01-08-2014, 02:12 PM
I'm really 2slow
2fast4u831's Avatar
when you put on the TPS sensor, did the TPS pin go in the window slot of the throttle body? kinda looks like this |I|
Old 01-08-2014, 02:13 PM
JdmRex805's Avatar
Yeah made sure it was in between. I even switched out the sensor but it gives same readings for closed and wide open throttle?
Old 01-08-2014, 02:19 PM
JdmRex805's Avatar
Only other thing I did was change the throttle body pulley to a non gsr so i can run the type r cable. But that seems to working fine as far as opening and closing the butterfly
Old 01-08-2014, 02:23 PM
I'm really 2slow
2fast4u831's Avatar
double check your plugs to make sure they aren't mixed up. It has happened to me. I had the TPS sensor switched with the MAP sensor. haha.
Old 01-08-2014, 05:21 PM
JdmRex805's Avatar
Just checked it and it's the correct plug. Was hoping it was that easy lol
Old 01-08-2014, 05:36 PM
JdmRex805's Avatar
Anyone else have any ideas what it could be?
Old 01-09-2014, 04:21 PM
I'm really 2slow
2fast4u831's Avatar
unscrew the TPS and check it outside the throttle body to see if the voltage changes. If it doesn't you have either a wiring problem or bad ecu.
Old 01-09-2014, 06:54 PM
JdmRex805's Avatar
I have to wait until tomorrow but I'll try that. Now to check the wiring, the green wire I would be checking for continuity to the neg terminal on batt. And yellow should give me a reading of 5V right? And for the red wire I should check continuity to D1 pin?
Old 01-10-2014, 12:59 AM
holmesnmanny's Avatar
Should be 5v reference on one, ground on another, and the other will be the signal which is what you want to test.
Since you say you're getting 5v that could be the 5v reference wire...it's not always the middle wire that's the signal voltage.
To confirm, unplug it and check for voltage again, obviously if that's the signal wire you should get nothing now.
Also, if that is the signal wire there's no way you should be getting 5v ...should be maybe 4.6 max
Old 01-12-2014, 08:12 AM
GhostAccord's Avatar
YEL = (+) 5v
RED = (Sig) Approx. 0.5v closed throttle and approx. 4.5v WOT
GRN = (-) Ground
I always find it easiest to back probe these sensors when testing the voltage. Keep the connector hooked up and stick a small pin/needle into the back of the connector between the weather seal and the wire.
If you are seeing 5v from the signal wire at closed throttle. I would assume that the TP sensor could be bad or it is not installed properly on the throttle shaft.
Old 01-12-2014, 09:05 AM
turbonetics3597's Avatar
I had a similar problem on my gsr when i put on s2 intake & throttle body what happend was the cable didnt sit properly so had to cut the bracket on the throttle body and weld it back works fine. 5.03 to 5.06 i would say the harness or wiring because thats not even close to the window voltages I'll post a pic
Its kind of hard to see but i cut a v out of it and bent it back down because i was only getting 50 percent at wide open
Old 01-12-2014, 03:01 PM
JdmRex805's Avatar
Originally Posted by GhostAccord
YEL = (+) 5v
GRN = (-) Ground
That's exactly how I'm doing it, going in between the weather seal and wire. I found a break in the ground wire and fixed that. Yellow wire I'm getting 5v. Now that the ground is fixed I do get different reading from the red middle wire when turning the tps. But it's 4.5v close amd 1.122v wide open? Cel went away but my idle still goes up to 2k when warming up.
Old 01-12-2014, 03:21 PM
JdmRex805's Avatar
Already replaced the tps. When installing I'm making sure the pin on tps is going in between the slot on tb and turning tps a little to put in the bolts. The throttle pulley does open the butterfly fine don't see it getting stuck anywhere. Before I fixed the ground voltage didn't change at all when turning the tps now it does but no where near .45v range when closed
Old 01-12-2014, 03:23 PM
JdmRex805's Avatar
Someone mentioned the ecu so I plugged in the jumper harness and the obd1 ecu but I'm getting same readings?
Old 01-12-2014, 04:06 PM
I'm really 2slow
2fast4u831's Avatar
what quality multi-meter do you have? did you try adjusting your TPS?
Old 01-12-2014, 05:51 PM
JdmRex805's Avatar
It's a craftsman 82400. Yeah I did, at closed throttle ranges from around 4.1-5.5 so I set it to 4.5v. At full open throttle it reads 1.122v. I tried adjusting it at full open to see if I could get it to .45v but it goes no lower than 1v
Old 01-12-2014, 05:53 PM
JdmRex805's Avatar
Before fixing the break in the ground wire, it would give me only 5.06v closed and 5.03v open and no change when adjusting the tps
Old 01-14-2014, 12:28 AM
It would appear your voltages are backwards. Somehow they are swapped coming from the ecu. You need to trace the wiring.
Old 01-14-2014, 04:40 PM
I'm Huge In Japan
VegasInvasion's Avatar
This can also happen due to an improper ground, particularly the one on the thermostat. Very common problem on swaps. It's also common to improperly install the TPS, it can be a tricky procedure. I believe there are threads on that.
theEG6
12-23-2013 06:58 AM
overdrivemag
03-11-2012 04:31 PM
Olivemyhonda
18
03-12-2008 07:22 PM
civicandy
09-23-2007 12:21 PM
Quick Reply: Problems calibrating tps on gsr
