line bore- what is it?
Old 12-04-2002, 04:28 AM
torr's Avatar
Default line bore- what is it?
can someone please explain to me what line bore is. i'm gonna get my block sleeved by golden eagle and most of the post mentioned line bore. i have no idea what that means. thanks
Old 12-04-2002, 05:22 AM
nolimits's Avatar
Default Re: line bore- what is it? (torr)
Boring the cylinders to a larger diameter to accomodate larger pistons or sleaves.
Old 12-04-2002, 05:53 AM
jlicrx's Avatar
boring horizontally through the crankshaft main bearing journals to make sure the crank isn't in a bind.
Old 12-04-2002, 06:38 AM
rastropovitch
Guest
Posts: n/a
Line boring refers to the boring method that touches several surfaces at once.
Schu
Old 12-04-2002, 03:17 PM
earl's Avatar
Well it's actually align bore, not line bore. Sometimes when installing sleeves, the block gets twisted up and throws the main bearing saddles out of alignment. When you install the crank, it will freeze up rather than spin easily. Align boring straightens everything out. Not a great thing to have to do to a block as it messes up all the stock geometry.
Old 08-02-2010, 07:56 AM
low13da9's Avatar
tt
Old 05-13-2016, 03:20 AM
pr40574's Avatar
Had to do align boring to my B18C, Darton sleeved. Is it true this job may make the aligning of the oil pump gear difficult?
Old 05-13-2016, 04:34 AM
motoxxxman's Avatar
99% of the time, no.
b18sihatch
07-06-2006 02:41 PM
duceduce22
12-28-2004 04:29 PM
Bnjmn
07-04-2003 04:27 PM
earl
01-29-2003 02:51 PM
BoostedH23a1
01-21-2003 02:04 PM
Quick Reply: line bore- what is it?
