what is a vtec controller?
Old 05-08-2003, 04:18 PM
ahunt01's Avatar
Default what is a vtec controller?
I know this is a dumb question, but what exactually does a vtec controller do? I'm guessing you can program your car to engage vtec at lower RPMs? What would be the benifit/downside to that?
Thanks
Old 05-08-2003, 05:03 PM
sslude's Avatar
Default Re: what is a vtec controller? (ahunt01)
well there is a VAFC which is a vtec and air fuel controller, it basically lets you fine tune your fuel and vtec engagement point. its a nice mod if you have IHE and a couple other parts
Old 05-08-2003, 07:53 PM
blah13's Avatar
Default Re: what is a vtec controller? (sslude)
The VTEC Controller does just that, allows you to change VTEC engagement. The V-AFC adds air/fuel control as well. What you do is have 2 runs(or more) on a dyno, 1 with the small lobe up to redline and the next with the large(VTEC) lobe up to redline. You then compare the 2 torque curves and set VTEC to engage where they cross over (the small lobe drops in power vs the large lobe continues to make power) Badda bing.
Old 05-09-2003, 03:29 AM
ahunt01's Avatar
Sounds like a nice addon, thanks for the help everyone.
Old 05-09-2003, 08:02 AM
Resurgent's Avatar
Also good for adding a vtec head to a non vtec engine
pokmijn
11-24-2007 07:28 PM
SOHC_MShue
09-18-2002 09:27 AM
06Xrunner
09-07-2002 07:06 PM
RexB16
05-04-2002 03:27 AM
CivicEsEye
01-05-2002 02:21 PM
Quick Reply: what is a vtec controller?
