my alternator/charging system problems
Old 09-15-2003, 06:43 PM
daver's Avatar
Default my alternator/charging system problems
A recent '95 jdm gsr engine into a '94 eg hatch swap.
had the typical charging system failure symptoms and then the car dies. I change the alternator, still not kicking out 14.4 volts, drive it around a bit, seems to be fine. A few days later now (car sat), the battery light comes on then everything fails.
The battery light never came on with the first alternator in there. and the light only comes on at low rpms.
I've tested about everything i can think of except for this supposed fusable link that i can't find. Grounds seem to be good. Fuses look good. ECU?? better not be.
can anyone help? this sucks. BTW im using a d16 harness
thanks,
d
Old 09-15-2003, 06:55 PM
Eyewitness's Avatar
Default Re: my alternator/charging system problems (daver)
Make sure nothing is shorting out in the car....sounds like thats the problem....
Old 09-15-2003, 10:22 PM
daver's Avatar
Default Re: my alternator/charging system problems (Eyewitness)
thanks for the response. Any idea of how to check for shorts?
Also, does the ecu ground by being bolted in. Its sitting on the carpet now. Just a thought i just had.
d
Old 09-16-2003, 11:08 AM
daver's Avatar
anyone have ideas, i'm reading power coming off the big fat wire from the top of the alt., but the battery isn't being charged. Am i doing this right?
d
Old 09-16-2003, 06:56 PM
daver's Avatar
i checked the chassis harness of a handy dandy '92 eg i had sitting around and it seems there are several extra wires it has that my '94 doesn't.
Besides the vtec wires, and the auto tranny wires, it has wires i A12 and A16. The hybrid site lists them as an "engine coolant temp switch" for the A12 and alternator "ALT C" for a16. As per the p72 obd1 ecu pinouts list
My '94 civic doesn't have these wires. I assume the p72 might need them. Anyone else run into this? Sounds like a possible solution to my alternator problems...
d
Old 09-22-2003, 08:19 AM
daver's Avatar
that a16 goes to the alternator, didn't make a difference tho. Putting the third alternator on there in 1 week did tho. friggin dud alternators wasting my time.
d
Slacker87
17
05-10-2017 07:30 AM
nikez4me
07-10-2011 09:25 AM
mayfly
06-28-2009 04:34 PM
fe519
09-23-2003 03:25 AM
Alexnaderkeith
09-10-2003 08:32 AM
Quick Reply: my alternator/charging system problems
