How hard is it press out wrist pins on oem honda pistons?
Old 03-15-2009, 10:34 AM
JDMCRX's Avatar
Default How hard is it press out wrist pins on oem honda pistons?
Can i make a shaft to press the pins out on my press ??
Old 03-15-2009, 01:21 PM
nitroice40's Avatar
Default Re: How hard is it press out wrist pins on oem honda pistons?
yes. I use a 11mm socket I think.
Old 03-15-2009, 01:44 PM
triniskill's Avatar
yes you can or as above ^^ said a 11mm deep socket.
Old 03-15-2009, 02:37 PM
JDMCRX's Avatar
I was thinking of cutting a piece of 2x4 like half of it 81mm so the piston will sit in it and i can use the 11mm socket to press down on the wrist pin to push it out. Im just trying to save some coin places around here want $60-80 to take off and intall pistons. I got access to a press.
Old 03-15-2009, 02:49 PM
NJIN BUILDR's Avatar
Take your time and get a good fit between the piston and the base your pressing against.If your tossing the pistons it's not as important,but if your going to reuse them it is critical.I heat the rod to assemble them.You only need a light straw color,you don't want it glowing red.
Old 03-15-2009, 05:06 PM
triniskill's Avatar
you can do that...take your time and make sure u have a hole in the wood for the wrist pin to fall through...yea thats a usual price for a machine shop to remove n reinstall pistons..basically a hour labor
Old 03-15-2009, 05:20 PM
JDMCRX's Avatar
Ok im just trying to do a budget ls setup . I got a set of GSR pistons im gonna slapp on the LS rods after i send them to get arp's put in them.
TravisBiggie
05-27-2012 05:45 AM
ZombiePharoh
04-16-2012 04:47 PM
Hoosier Daddy
11-07-2003 12:53 PM
CRXGSR
11-04-2002 05:47 PM
Quick Reply: How hard is it press out wrist pins on oem honda pistons?
