i have heard people talking about stroker kits, so i have a question
Old 04-28-2002, 06:37 PM
New User
4wsB21a's Avatar
Default i have heard people talking about stroker kits, so i have a question
if the stroker kit is suppose to make a motor like the 1.8 into a 2.0, how does it do that? does the crankshaft now have a longer stroke, or shorter stroke? what about boring out the block for the bigger pistons? is that also needed in order ot have the motor be stroked? does this make sense? i guess i am really just asking how a stroker kit works. thanks.
Old 04-28-2002, 06:56 PM
earl's Avatar
Default Re: i have heard people talking about stroker kits, so i have a question (crxplus)
Nothing more than adding a longer stroke to your motor. You can do it with the same bore size. However you have to change your pistons and rods at the same time because the geometry gets all screwed up. Therefore you could bore the block and gain size thru the bore and the stroke. Basically the stroker crank pulls the piston deeper into the block thus adding liters (cubic inches) to your motor size.
Old 04-29-2002, 04:48 AM
New User
4wsB21a's Avatar
Default Re: i have heard people talking about stroker kits, so i have a question (earl)
that's what i thought. what would happen if you put in a shorter stroking crank in a larger motor? (just for an example, a 1.8 crank in a 2.0)
[Modified by crxplus, 1:49 PM 4/29/2002]
Old 04-29-2002, 04:52 AM
MrFatBooty's Avatar
Playing with the stroke will change your powerband. A longer stroke tends to shift the power to lower RPM for example. Longer stroke also generally means your pistons have less dwell time at TDC which affects cam choice. An example of this is skunk2 Stage 1 cams. They work great in B16's because they have a short stroke which provides lots of dwell, but in B18's which have less dwell they tend to perform like ***.
BTW, dwell at TDC means the amount of time your pistons are stationary at top dead center i.e. how long they're chillin at the top of their stroke.
Old 04-29-2002, 06:35 AM
earl's Avatar
Shorter crank (or stroke) would take size out of the motor. Shorter stroke usually means higher rpm capability as MrF. says.
everyonesnaturalenemy
05-24-2007 05:03 AM
inkong
02-27-2007 02:57 PM
EVOCELICA
02-25-2003 11:26 AM
BluntMan
12-24-2002 09:22 PM
DA DA DA JDM
12-12-2002 10:58 PM
Quick Reply: i have heard people talking about stroker kits, so i have a question
