HELP!!! with my Clutch Pedal
i got a 92 si, I was trying to start it yesturday, after i rewired the cabin harness, when i press my clutch down, it will stay there and i have to pull it back with my hands and when i pull it back it clicks like 3 to 5 times somewhat in a small way simalar to handcuffs clicking, and i cannot start my car. Any help?
Re: HELP!!! with my Clutch Pedal (dc2-guy)
its hydraulic, and yes cabin harness. Its the harness that is located under the dash, that connects to the ecu goes accoess both sides and ends up in the engine bay. Okay so after i connected all the wires i go to start it. The clutch was really stiff, so i go to press it again and it goes all the way down and gets stuck. i had to pull it back out. I couldnt even get the car started cause of the clutch. One of my friends told me that it could be the engine was replaced and they didnt bleed it, but shouldnt my car start anyways?
Re: HELP!!! with my Clutch Pedal (SiRay13)
shouldnt my car turn though? even though if there was no fluid? cause right now, its as if im not even pressing the clutch? Cause you know on most 5spd cars you need to press the clutch to start it, its as if i aint pressing it. what could it be? imma bleed it tonight and see that happenes, any ideas?
iridebiketrials
12-05-2003 10:05 AM
