Help
Old 04-02-2016, 12:24 PM
Cody Wilson's Avatar
Default Help
I have a 2000 Honda civic ex. The issue of the day is that my car will not start. I have tried to jump it which did not work. Only after I switched a relay or 2 around in the fuse box. Went to advance to see get my battery and alternator checked everything is fine with battery running at 12.9 volts the minute I tried to turn my car over it won't even click I am now thinking it could be a high possibility of the ignition relay or neutral safety switch. Any ideas?
Old 04-02-2016, 12:26 PM
Default Re: Help
I also have no power to my car automatic locks will not work so maybe a bad alternator or cables?
Old 04-07-2016, 02:47 PM
kwade9015's Avatar
Have you checked the main relay?
Old 04-07-2016, 04:30 PM
fcm
Old Fart
fcm's Avatar
Default Re: Help
If you have no power at all, the the main fuse ,in engine bay fuse box, is blown.
If you do have some power then go to the tech form and fallow the simple DIY starter/circuit test, in the sticky, all you need is a simple 12V test light, [not LED type]94
Old 04-07-2016, 04:38 PM
kwade9015's Avatar
That's it!
arborguy
Honda Civic (2006 - 2015)
11
12-28-2016 05:29 AM
1993gsrcivic
04-10-2009 11:14 AM
b20vtech
03-26-2006 11:01 PM
Mugen Dom
11-13-2001 08:32 AM
Quick Reply: Help
