Are h22 piston tops ceramic coated?
Arriving somewhere but not here
My searches keep bringing me back to turbo builds and people sending out for ceramic coatings, mine are from a jdm 4g prelude with the older closed deck motor. Was thinking of giving a set a mirror buff before putting back in my motor to help carbon build up but if they are coated then I probably won't touch them.
Re: Are h22 piston tops ceramic coated?
Bump, maybe I'd of been better off in the prelude section? Didn't find anything in the h22 service manual either, just piston to wall clearance and I think stuff about the skirt coating for the FRM but nothing about the tops
if your looking to clean the TOPS of your pistons you can just use a wire brush. i dont believe there ceramic coated
I like polishing them, I just use a dremel with different attachments. I have a little set of scales to bring them back to the same weights. It's worked alright on my other motors to stop carbon trying to cling and reflect a bit of heat. Throw some water injection at it and you have really nice clean cylinders.
sadam-insane
06-09-2008 07:02 PM
Ryan C
06-09-2003 07:58 PM
The_In_Kid
08-10-2002 01:53 AM
