Camshafts
Old 12-23-2002, 06:11 PM
Bullet50's Avatar
Default Camshafts
Building a boosted B20.............. (formerly a B20B)
What should I use for cams? I've had some people say "stay with the stock B20B intake and exhaust". I've also had other people say "use the B20Z intake and keep the B20B exhaust". Yet again others have said "get cams from an LS integra non-vtec B18", and finally others say "go for aftermarket cams from Crower or Crane"
Lots of options but nobody can seem to back up their suggestions with performance data or personal experience. I don't really want to f**k the engine or loose performance because someone "thought" they had the answer.
Anybody with suggestions and something to back them up, I'd greatly appreciate them.
Thanks B50
Old 12-23-2002, 07:37 PM
non-VTEC's Avatar
Default Re: Camshafts (Bullet50)
Crower 62402T turbo cams high lift, low overlap/duration makes it perfect for high boooost
remember to get the dual valve springs and ti-retainers as well.....
stock cams will work fine........but you will only get so much from them before they start becoming a restriction.........but that depends on how much boost you want to run as well...
Old 12-23-2002, 07:53 PM
advanracing62's Avatar
Default Re: Camshafts (non-VTEC)
I've heard that running LS cams is better... can't remeber where I heard that, and I don't know if it's true.
Old 12-24-2002, 02:59 AM
Bullet50's Avatar
Thanks............. I'll check into those.
B50
blitzman
02-28-2018 02:49 PM
slo_hatch
10-22-2008 10:21 PM
Turboredteg
02-11-2005 08:15 AM
silver_nteg
03-30-2004 09:02 PM
ef ect
08-28-2002 05:39 AM
Quick Reply: Camshafts
