Gas=beer help
Old 11-22-2015, 06:16 PM
shawn_crx's Avatar
Default Gas=beer help
Engine = b20 with ycp high comp piston vtec b16 head with GSr cam.
Engine running fine, idle set to 850, timing 16 degree, but just idling the car for 10 min it burn thru 1/4 tank of gas.
Why so much gas used.
Exhaust are brand new, 3" cat back, and stock injectors. My 440cc runs rough, fuel pressure set to 37 lbs, 255lph fuel pump.
Need help to trouble shoot high fuel usage
Old 11-22-2015, 06:17 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: Gas=beer help
Because your tune is nonexistent. Get that thing tuned.
Old 11-22-2015, 07:45 PM
Hysterically Calm
TomCat39's Avatar
No car present, only an engine. Moved to Tech/Misc as this isn't about a car, only a motor in some mystery vehicle.
Old 11-23-2015, 05:24 AM
RTFM
v4lu3s's Avatar
You are burning a ton of gasoline because you are giving the car at least double what it should have it sounds like. original injectors 240cc, now 440cc, original pump probably 130lph, now 255lph....needs to be tuned...
Old 11-23-2015, 07:53 AM
shawn_crx's Avatar
93 civic hatchback
riceball777
05-22-2015 11:57 AM
thewrai6th
05-17-2011 01:00 PM
bazoOKA_ TOoth
12
09-30-2010 02:45 PM
phoshyzzle
Engine Management and Tuning
14
04-14-2010 04:48 PM
datnigabluberry
03-29-2007 05:53 AM
Quick Reply: Gas=beer help
