Fan Help!
Fan Help!
anyone knoe how to wire one of my Fans to turn on (the INTAKE side, passenger) to a switch so i can turn it on and off. I heard this is possible, and would like to knoe how. If its not possible, than sorrie for wasting your time.
I have a 97 honda civic dx hatchback.
all help appreciated.
eddie
eddie
Re: Fan Help! (djeddiebear)
well it's surely possible, just want to know if you have a doubble fan setup la FAL fan or something, just unplug the second fan, then wire it with a relay, don't forget the relay!!! you must absolutly have one, if not you will fire up you dash, switch will becaume hott like Hell and Burn !!!
if you are not friendly with electrical connection, just go to an electrical shop they will charge you something like 30$ or so for that!!!
Re: Fan Help! (kranked91dx)
get a electronic fan swich it senses the engine temp and then turns on your fan it is only like 14dollars from discount auto. or just get a 12vt swich
Re: Fan Help! (JDM EG CPE)
wich one the 12volt swich or the adjustable electronic fan sensor. the fan sensor just plugs into the positive and negative and a ground and the 12 just hot wired to the battery with a fuse.
EscoSi
02-01-2012 06:24 AM
littleblue
10-14-2008 04:44 AM
