engine bolt sizes, bolt torque, diagrams(2001 gsr listed)
Old 09-23-2010, 06:09 PM
raverx3m's Avatar
Default engine bolt sizes, bolt torque, diagrams(2001 gsr listed)
ive made the mistake that many people make while rebuilding the engine.
didnt use ziploc bags to keep the bolts and nuts sorted.
ended up with alot of bolts and dont know where which goes.
didnt know the length of the bolts.
turns out its very easy to get that info:
http://www.acuraautomotiveparts.org
all the bolt sizes are listed in the charts
but i will list them here for reference and list the thread pitch as well
that is found in honda service manual. as well as torque for each set of bolts.
bolt length is shown in the image below
hondaautoparts lists bolt thickness and bolt length
service manual lists bolt thickness and thread pitch
breather chamber
14 95701-10020-08 BOLT, FLANGE (10X20) torque 10lbf/ft
camshaft timing belt cover
18 90007-679-000 BOLT A, TIMING BELT COVER torque 7.2 lbf/ft
19 90010-PR3-000 BOLT, TIMING BELT COVER torque 7.2lbf/ft
21 90026-PR3-003 BOLT, TENSIONER torque 40lbf/ft
22 90031-PV0-305 BOLT-WASHER (10X30) torque OEM 41lbf/ft(skunk2 cams 22lbf/ft)
25 93404-06012-07 BOLT-WASHER (6X12) ?
crankshaft piston
7 13204-P72-003 BOLT, CONNECTING ROD torque OEM 33lbf/ft ARP bolts use strethch gauge, approx 50-55lbf/ft
18 90017-PR3-003 pulley BOLT-WASHER (14X31) torque tighten to 145lb/ft loosen, retighten to 130lb/ft
cylinder block oil pan
17 90001-PM3-003 BOLT, DRAIN PLUG (28MM) torque 58lb/ft
18 90007-PAA-T01 BOLT-WASHER (11X121) torque 49lb/ft
19 90007-P75-003 BOLT-WASHER (11X90) torque 56 lb/ft
20 90008-PR3-000 BOLT A, ENGINE MOUNT BRACKET (10X60) torque 40lb/ft
21 90009-PH1-000 BOLT, DRAIN PLUG (14MM) torque 33lb/ft
22 90009-PR3-000 BOLT B, ENGINE MOUNT BRACKET (10X40) torque 40lb/ft
28 94050-06080 NUT, FLANGE (6MM) torque 8.7lb/ft
32 95701-06014-08 BOLT, FLANGE (6X14) torque 8lb/ft
33 95701-06018-08 BOLT, FLANGE (6X18) torque 8.7lb/ft
34 95701-06020-08 BOLT, FLANGE (6X20) torque 8lb/ft
35 95701-08030-08 BOLT, FLANGE (8X30) torque 17lb/ft
36 95701-08035-08 BOLT, FLANGE (8X35) torque 17lb/ft
39 95701-12035-08 BOLT, FLANGE (12X35) torque 42lb/ft
40 95701-12050-08 BOLT, FLANGE (12X50) torque 42lb/ft
cylinder head
16 90002-PJ7-010 BOLT, FLANGE (6X45) 006 torque 7.2lb/ft
17 90002-PR3-000 BOLT, FLANGE (6X55) 002 torque 7.2lb/ft
18 90004-PE2-005 BOLT, SEALING (10MM) 001 torque 24lb/ft
19 90006-P72-003 BOLT-WASHER (11X164) 010 torque 63lb/ft
20 90014-PR3-000 BOLT A, HEAD COVER 004 torque 20lb/ft
30 95701-06018-08 BOLT, FLANGE (6X18) 003 torque 8.7lb/ft
31 95701-06030-08 BOLT, FLANGE (6X30) 003 torque 8.7lb/ft
32 95701-08050-00 BOLT, FLANGE (8X50) 016 torque 20lb/ft
cylinder head cover
18 90012-PM7-000 BOLT B, HEAD COVER 004 torque 20lb.ft
20 90212-PR3-000 NUT, HEAD COVER 004 torque 7.2lb/ft
21 90213-PH3-000 NUT, CAP (6MM) 008 torque 7/2 lb/ft
exhaust manifold
intake manifold
oil pump/strainer
PS pump
throttle body
water pump sensor
[img][/img]
[img][/img]
[img][/img]
i will add more when i get back this thing takes forever
benitom
Suspension & Brakes
16
10-14-2008 04:46 AM
KFMRC
Honda S2000
05-18-2006 11:08 AM
BoostinEJ1
41
04-16-2006 01:18 PM
shutta
01-20-2006 10:35 AM
Sleepy86o
11-10-2005 03:52 AM
Quick Reply: engine bolt sizes, bolt torque, diagrams(2001 gsr listed)
