burning oil at high rpm after using Seafoam. compression and leakdown fine
Old 04-30-2006, 08:13 PM
model x's Avatar
Default burning oil at high rpm after using Seafoam. compression and leakdown fine
I've got a boosted b16 and I'm getting blue smoke at high rpm and I'll go through a litre of oil during a track day. I'm pretty positive I only started burning the oil since I ran some seafoam through the intake and in the crankcase, which makes me think the carbon that was probably helping my oil rings is gone and they aren't sealing anymore. I did a compression test and the results were 208,208,210,225 and I performed a leakdown test and there was very little leakdown, 10%. I think this also points to bad oil rings.
I also have my vavle cover vent open, theres no oil in the intercooler pipes, and I'm using 15w-40 shell oil.
I'm I on the right track?
Old 04-30-2006, 08:24 PM
SkRiBLaH's Avatar
Default Re: burning oil at high rpm after using Seafoam. compression and leakdown fine (model x)
does it look like oil is coming from your exhaust ports?
could be valve seals.
Old 04-30-2006, 08:39 PM
model x's Avatar
Default Re: burning oil at high rpm after using Seafoam. compression and leakdown fine (SkRiBLaH)
wouldn't valve seals mean smoke at start up and idle where vacuum is highest?
Old 04-30-2006, 09:49 PM
SkRiBLaH's Avatar
not allways
Old 05-01-2006, 06:43 AM
ramennoodles's Avatar
maybe it's leaking through turbo seals
Old 05-01-2006, 06:48 AM
model x's Avatar
Default Re: burning oil at high rpm after using Seafoam. compression and leakdown fine (ramennoodles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramennoodles &raquo;</TD></TR><TR><TD CLASS="quote">maybe it's leaking through turbo seals</TD></TR></TABLE>
intercooler piping looks clean though
Old 05-01-2006, 06:53 AM
maybe it's just leaking on the exhaust side?
Old 05-02-2006, 02:22 AM
model x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramennoodles &raquo;</TD></TR><TR><TD CLASS="quote">maybe it's just leaking on the exhaust side?</TD></TR></TABLE>
I suppose its possible but how would I check that?
Old 05-06-2006, 12:03 PM
model x's Avatar
I pulled my pistons and rods and found cracked ring lands on #2 and #3 pistons.
jonyi27
04-21-2014 11:55 AM
Jeff
04-18-2005 06:23 AM
RvisionGSR
03-19-2004 09:44 PM
Accel Junky
04-28-2003 02:18 PM
AMChev
09-15-2002 10:26 AM
Quick Reply: burning oil at high rpm after using Seafoam. compression and leakdown fine
