Broke fucking water pump bolt off in block!! HELP
Broke ******* water pump bolt off in block!! HELP
so was putting on water pump and the bolt broke off in block. tried to get it out only made it worse, now its IN IN the block..... will my water pump leak if i dont drill it out or should i just not make a bad thnig worse?
Re: Broke ******* water pump bolt off in block!! HELP (jdmrhdtt)
Yea, but you better make damn sure that you can drill straight..... They are the **** if you can use it right. I had to helicoil a sparkplug hole on a subaru once. I used lots of red thread locker on the coil. It worked well.
remove pump
remove hondabond + residue
clean gasket surfaces again.
With the pump off the bolt should stick-out about 3-4mm, enough to grip it with some pliers.
Dont take shortcuts and hope it'll be ok. ITs your project, so take pride in it dude.
Re: (0TT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0TT »</TD></TR><TR><TD CLASS="quote">remove pump
Dont take shortcuts and hope it'll be ok. ITs your project, so take pride in it dude.</TD></TR></TABLE>i think he said its actually broken inside the block...
*anyhow, on with the issue... helicoil the damn thing. just do it straight.
GSR_ITR_BOIB
09-19-2013 01:41 AM
