Brake Fluid and Paint removal on Plastic
Old 04-09-2012, 09:42 AM
zaxfire69's Avatar
Default Brake Fluid and Paint removal on Plastic
Hey guys. Here is a helpful tip for you if you have painted your stock plastic inside your Honda and want to take it back to stock color. Soak your plastic pieces in brake fluid to take off that spray paint Fast. I am working on my Speedo bezel right now. Had 2 layers of paint on it. After 1 hour of soaking in brake fluid the paint just wipes off with a paper towel. I almost wasted 40 bucks on a new bezel. After you have removed all the paint wash the plastic part off with soapy water and dry. Saved me 40 dollars. I used Walmart Super tech dot 3 fluid.
Old 04-09-2012, 10:26 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Brake Fluid and Paint removal on Plastic
I "heard" oven cleaner works well too but I haven't tried it.
Old 04-09-2012, 10:35 AM
zaxfire69's Avatar
Well Brake fluid works wonders! My gauge bezel is good as new! Oven cleaner may do the trick as well. Also heard Wd-40, but don't know how true that is..Brake fluid FTW!
The AW Alchemist
Paint and Body
07-09-2009 09:49 PM
matryx
10-05-2007 01:08 PM
Sketch_hs
10
02-28-2006 11:11 PM
IV_SHO
09-12-2004 04:04 PM
Quick Reply: Brake Fluid and Paint removal on Plastic
