ITR head ?
Old 03-27-2009, 07:30 PM
Japankid's Avatar
Icon2 ITR head ?
How can i tell if it's a ITR head with out pulling off the valve cover
i know about the dual springs
Valvesprings & Retainers the dual springs
Old 03-27-2009, 10:28 PM
J_Marc's Avatar
Default Re: ITR head ?
There's only really two b-series vtec heads, b16a/b18c5 and b18c1. Is the head on a motor, assuming it is look at the intake manifold. If it's a stock intake manifold and it's a gsr manifold, then you have a b18c1 head, that would be the simplest way of knowing.
If it has a stock intake manifold and it's not a gsr, you are looking at either a b16a or b18c5 manifold. b16a/b18c5 head castings are the same design, b18c5 heads had no more than minor hand porting and a valve job done before assembly. They have slightly different valves and dual valve springs. Without taking off the valve cover the intake isn't solid proof of anything even if you know what a b16a mani looks like and the ITR mani looks like, a b16a mani could be on the ITR head and an ITR mani could be on the b16a head.
Search the FAQs for any specs you can find on b-series motors and ITR motors, there are stamps on the head castings, I don't recall many details about those, but it could be an other way of identifying the head.
Old 03-27-2009, 10:45 PM
iwanttokillgod's Avatar
wow you have all this type r stuff for sale and you dont know your ****
Old 03-28-2009, 04:53 AM
PYDB8-R's Avatar
The easiest way is to look for the green paint that is put on at the factory where the furthest rear bolt on the dizzy goes, looking straight down at the head there will be that flat spot about 2"x3/4" where there should be green paint. Sometimes it gets cleaned off from pressure washing the engines but you can usually still see a little bit of green if you look hard enough.
Old 03-28-2009, 07:39 AM
Japankid's Avatar
thanks for the input do u have any link's or pics, the head
has a pr3-3 stamp i dont see any green bro on the head
Old 03-28-2009, 07:43 AM
Japankid's Avatar
i do buddy just trying to make sure cuz i was going to sale it and was not sure!
some pics of the head
Old 03-28-2009, 07:44 AM
Daisy... Daisy...
Dogginator's Avatar
PR3-3 does not mean a thing. Here is my old FS thread with ID pictures and links.
http://www.hondamarketplace.com/show....php?t=1493391
Old 03-28-2009, 07:30 PM
PYDB8-R's Avatar
Any pics from the same angle looking into the intake ports?
Old 03-28-2009, 07:32 PM
Daisy... Daisy...
Dogginator's Avatar
Umm...
Originally Posted by Dogginator
Intake Port Showing ITR Valves and Porting:
Old 03-28-2009, 09:37 PM
Japankid's Avatar
i think i have to pull the manifold know. how about pr3-4 ?
Old 03-29-2009, 01:36 AM
PYDB8-R's Avatar
Umm... I was asking for a pic from Japankid of his head.
paulITR
05-31-2006 02:48 PM
gamakichi77
11-07-2004 06:41 PM
gsr squirrel
04-03-2002 01:37 PM
vtec69
03-04-2002 10:59 AM
Quick Reply: ITR head ?
