install 340lph pump and pressure drop?
Old 06-02-2011, 12:54 PM
eg:R's Avatar
Default install 340lph pump and pressure drop?
ive replace my 255lph with a 340lph and my fuel pressure drop 6psi on my gauge on the rail. is it suppose to do this?? i thought the pressure should go up knowing its a higher pressure pump. anyone have a ideal if this is correct.
Old 06-02-2011, 08:24 PM
slowcivic2k's Avatar
Default Re: install 340lph pump and pressure drop?
Pumps do not create pressure, they create flow. Hence the Liters per Hour rating, not PSI......
Your fuel regulator is what allows pressure to build, giving the pump something to fight against.
Old 06-02-2011, 10:12 PM
eg:R's Avatar
What is the max base pressure I can run to be on the safe side ? I had it On 80psi with the 255 and it drop to 76Psi after installing the 340 pump.
Old 06-03-2011, 02:44 AM
non-VTEC's Avatar
what kind of fuel regulator are you using?
Old 06-03-2011, 04:41 AM
The Grumpiest
grumblemarc's Avatar
Why are you running the pressure so high?
Old 06-03-2011, 06:38 AM
eg:R's Avatar
I have the aem. I was trying to squeeze as much out of the 255 as possible cause I was running out of injector(1000cc)
eg:R
07-06-2011 01:21 PM
eg:R
06-06-2011 10:08 AM
SupaFly_Honda
07-24-2005 07:10 PM
BoostedD15B7
11-30-2003 03:52 PM
D16A6Turbo
12-17-2002 07:11 AM
Quick Reply: install 340lph pump and pressure drop?
