The difference in compression between B20B VS B20Z
Old 11-23-2009, 04:43 PM
  #176
Lambo123's Avatar
Default re: The difference in compression between B20B VS B20Z
Originally Posted by hester_b
has anyone got a b20 from hmotors i have read alot of good things about them they have a 146Hp 133Trq 9.6 compression (99-00) for 750 dollars i just dont want to get a 8.8 compression for that price lol
i bought my b20b through hmotors. motor looked almost brand new. mated it to a gsr tranny and i loved the setup. i'd give them a call first though to see if they have any b20z's in stock. they're getting hard to come by. also try importautosalvage.com. they might have a 99-00 usdm b20z. same specs as jdm.
Lambo123 is offline
Old 03-03-2010, 07:16 AM
  #177
420eg95's Avatar
Great info. But you need to mention that all of these motors are used, they could have had work done to them, things like cheaper non-honda head gaskets that will change compression, or thicker higher ones, when I ordered a stock b16 a few years back(non lsd) its came with a cusco LSD, I just happened to get lucky. and from what i understand when ever you order a used JDM stuff you always take a risk that internals have been changed, upgraded or even down graded.
420eg95 is offline
Old 03-03-2010, 08:47 AM
  #178
bhzrd_rs4's Avatar
i have a b20b 8,8:1 can i have 9,6:1 compression whit some modification??? greetings from chile
bhzrd_rs4 is offline
Old 08-03-2010, 03:42 PM
  #179
ysxe's Avatar
Originally Posted by kulo
anyone got specs on a b20b3
i cant find any
Ditto, I notice you are also from the uk. Im guesing the B20B3 is the uk B20b.
I just got one and it has no knock sensor, and the long girrafe intake. IM guessing its 8.8 compression.
IM thinking i will just get replacement pistons and bring it up to somewhere in the region of 11:1CR.
I will be using a vtec head, B16A/a2 or something similar.
I am aiming for 200+ fhp.
ysxe is offline
Old 10-11-2010, 04:21 PM
  #180
freeagent's Avatar
hey guess ive read most of the first pages but still un clear of wich cp ratio i have,
i just bought a 99 jdm b20b with long mani and p-75 head no knock sensor , 8.8? 9.2? idk plz help
freeagent is offline
Old 03-07-2012, 10:10 PM
  #181
Lozano1991's Avatar
You got the low cr.
The 9.2 comes with a p8r head
And the 9.6 cr comes with a knock sensor
Lozano1991 is offline
Old 03-13-2012, 10:53 AM
  #182
hondajdmb20b's Avatar
i have 99 to 00 jdm b20 with knock sensor. 9:6:1 cr. what numbers can i expect from the motor. trying to build a 12 se. car in the quarter mile what do u suggest. it is sitting in a 94 honda civic ex.
hondajdmb20b is offline
Old 10-31-2012, 01:57 PM
  #183
tony b20-vtec's Avatar
thats right !
tony b20-vtec is offline
Old 04-14-2013, 10:06 AM
  #184
el faster's Avatar
Thanks 4 the info b20z all the way
el faster is offline
Old 09-24-2013, 05:38 PM
  #185
EF9_TryMe's Avatar
So all b20z's are high compression motors? Why does the front page not get updated ?
EF9_TryMe is offline
Old 09-27-2013, 10:55 AM
  #186
TunerN00b's Avatar
Because you played
TunerN00b is offline
Old 03-06-2016, 06:40 PM
  #187
Totoracing's Avatar
Question i bought a b20b p3f with a p75 head but its has a knock sensor.... Does that make it high compression or a low compression can come with a knocksensor?
Totoracing is offline
Old 10-20-2016, 06:55 PM
  #188
Thacknasty's Avatar
Hey my name is Tim thacker and i have a 95 acura integra, and ive been having problems one right after another. So that leads me to this question, im completely tired of f***ing with this motor. Its a b20b in the teggy right now and im actually about to order a new motor tomorrow. Im looking at a b20z to put in it rather than the b20b, would i be able to use the parts off of my b20b and put it on my b20z? Is there a difference between the two? Other than the compression. Please get back with me as soon as possible like i said i would like to order the motor tomorrow please and thanks in advanced for the help!!
Thacknasty is offline
Old 10-21-2016, 06:52 AM
  #189
JRCivic1's Avatar
Mechanically, everything will interchange. Intake and exhaust manifolds, distributor... especially if you are using the stock '95 Integra engine harness and fuel injectors. The stock ECU is not optimum for a B20, but with an increase in fuel pressure (adjustable FPR), you should be able to get it at least safe. Ideally, you will need an ECU that you can tune... and then get to a local tuner who can dyno the car and make the parts that you have work optimally together.
JRCivic1 is offline
Old 07-18-2019, 02:01 AM
  #190
Pablomg's Avatar
Default Re: The difference in compression between B20B VS B20Z
9,2:1 cr = phk high comp + p8r head ( 47cc combustion chamber and 84mm bore )
P75 head has 45cc combustion chamber and 81mm bore, for this is the 9,6:1
Pablomg is offline
DevinW
09-26-2011 02:33 AM
KURUPTinc
08-07-2007 09:54 PM
simon98h22
12-09-2004 05:07 AM
Norcalstoppy
12-25-2002 03:18 PM
InfamousRS
09-21-2002 05:59 PM
Quick Reply: The difference in compression between B20B VS B20Z
