Automatic dash harness in a manual
okay so my dash harness is cut up pretty bad and I'm replacing it and the driver side too. I need the wires to the lights and to the rad fans also because I don't have them lol. Only thing is it's a manual and I've found an automatic. I already have the driver side (usdm). Is there no way this will work?
Re: Automatic dash harness in a manual
Is there a forum you could give me a link to that would tell me how to do this? I don't have the wiring under the fuse box yet. I can go to another junkyard and try to find that. But I'm the end the wiring from an auto car could work? Thanks . Just need a link if it will work
Vehicle info is needed to tell you how to bypass the park neutral switch ( year,make,model). All I did when I swapped the automatic harness into my eg was solder together the wires for the park neutral switch.
the harness that runs inside the dash board? that plugs into your fuse box, radio, heater, etc...
or the harness that runs along the firewall under the carpet? that plugs into the fuse box, and runs outside the car to the headlights, etc?
the harness that runs along the firewall. I cut it at the part that runs behind the dash. I'll have to solder it. But I have the rest.
Fish Twig
you will need to figure it out with a bunch of wiring diagrams. there is also a good chance that you will need a matching automatic engine harness for the engine harness to plug up unless you repin all of that too.
that's just the part that would plug into the bottom of the fuse box? Can anybody add to that?
I’m trying to switch the one inside my dash for power windows, would it matter which one then ?
slayersluck
05-15-2014 06:26 AM
Cap'N Chronic
07-14-2012 03:01 AM
civic-steve-94
11
10-31-2011 06:51 PM
95 civic b16
02-04-2009 07:28 PM
