jb weld question? wideband bung for downpipe...
Old 10-26-2004, 02:15 PM
djnikko's Avatar
Default jb weld question? wideband bung for downpipe...
Just out of interest...do you reckon JB weld will hold a bung in place in my downpipe? The bung is to be used for WB tuning?
Also what happens to JB weld when it reaches its melting point? does it melt? like a goo... or crumble like a powder?
Thanks in advance
Old 10-26-2004, 06:07 PM
Runnerdown's Avatar
Default Re: jb weld question? wideband bung for downpipe... (djnikko)
JB weld on the dowpipe??
Old 10-26-2004, 06:09 PM
drdisco69's Avatar
Default Re: jb weld question? wideband bung for downpipe... (Runnerdown)
Dude, it can't be more than like $5 to weld that thing in...
Old 10-27-2004, 02:15 PM
djnikko's Avatar
Default Re: jb weld question? wideband bung for downpipe... (drdisco69)
i just welded it myself in the end, it wasnt pretty and im sure theres a few gaps round the edges of the bung where it meets the downpipe, can i still use this for wideband o2 tuning? or will the gaps somehow affect the readings..
Im looking to get a stainless steel downpipe soon the one i have is mild and is rusting so i dont give a **** about it, just wanna get my car tuned and on the road
Old 10-27-2004, 06:03 PM
drdisco69's Avatar
Try to fill in the gaps, as they can draw in air and cause the sensor to read lean.
Old 10-27-2004, 06:46 PM
Banned
LSVTEC 91 Civic's Avatar
JB weld is awesome
Old 10-29-2004, 05:39 AM
djnikko's Avatar
Default Re: jb weld question? wideband bung for downpipe... (LSVTEC 91 Civic)
As I cant get into that angle with a welder, does anyone recommend brazing? Just so I can fill the gaps....
JB weld is the ****....
So has anyone seen JB weld melt or crack? Not from strain on the joint but heat related...
Cheers
Old 10-30-2004, 03:38 PM
djnikko's Avatar
anyone recommend the brazing?
Old 10-30-2004, 04:00 PM
Jim Truett's Avatar
I would braze it if you can get the heat where you need it. JB weld is only good to around 300 degrees F.
Old 10-30-2004, 04:17 PM
honda_power69's Avatar
Default Re: jb weld question? wideband bung for downpipe... (Jim Truett)
I agree, just braze it.
Old 10-30-2004, 09:56 PM
Def
Def's Avatar
JB Weld is good to 600*F and just melts when you exceed this, and yes, it will melt on a downpipe in no time.
Old 10-30-2004, 10:01 PM
Jim Truett's Avatar
Default Re: jb weld question? wideband bung for downpipe... (Def)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Def &raquo;</TD></TR><TR><TD CLASS="quote">JB Weld is good to 600*F and just melts when you exceed this, and yes, it will melt on a downpipe in no time.</TD></TR></TABLE>
Must be the slow set. I only had the JB Quik to look at.
Old 10-30-2004, 10:41 PM
msmotorsports's Avatar
JB weld is def. not resistant to high heat. Once super heated it will get brittle and break off into little pieces.
vtec-adykt
Welding / Fabrication
12-16-2004 12:05 AM
DualCamDan
11-13-2004 02:33 AM
Nextelbuddy
05-26-2004 10:16 PM
ion_four
09-15-2003 02:22 PM
Quick Reply: jb weld question? wideband bung for downpipe...
