2.0 GSR Knocking on 1st Startup of the day
Re: 2.0 GSR Knocking on 1st Startup of the day
check and clean your oil pick-up in the pan. also check that your pan has not been pushed up against the pick-up. iv seen loads hondas with this problem. Do you have oil squirters?
This is a fresh build with all new parts and the oil pick up was thoroughly cleaned. It only started to happen after i switched to fully synthetic oil. Yes i do have oil squirters
The motor has Arias high compression pistons is it normal for it to knock on cold startups with forged pistons? and if so why didn't it do it when i was using regular cheap oil? it only started happening after i switched to fully synthetic.
I Have a GSR And its noisy in the morning
81.5 mm Forged pistons
H-beam rods
acl bearings
My Engine has 17,000 miles on it
8,000 of that is at 260 plus horse power , dozens of 150+ MPH freeway pulls
and my engine has done the same exact oil light issue, takes a few seconds, it knocks for a about a second
I built my engine completly And Im almost 100% sure its normal
But check everything again like: Oil pan for dents(my has one right under the pick up that i do need to fix) things like that Good Luck!
H-beam rods
acl bearings
haha you can still search my threads Of almost the same question about 1 year ago hahahaha
I know how itis to have a fresh motor.... Sometimes i couldnt sleep at nigh
because i was scared my motor wasnt right hahahaha
Found it just for giggles
https://honda-tech.com/forums/tech-misc-15/hear-knocking-when-cold-starts-fresh-build-2235187/
