11.5 compression and higher peeps, what octane fuel you running?
Old 03-31-2003, 08:06 PM
H22coupe's Avatar
Default 11.5 compression and higher peeps, what octane fuel you running?
as the topic says, also what engine management you running?
Old 03-31-2003, 08:12 PM
sslude's Avatar
Default Re: 11.5 compression and higher peeps, what octane fuel you running? (H22coupe)
prolly 93, or higher, octane, i dont run that compression, just saying. id also say an AEM EMS or a hondata
[Modified by sslude, 9:12 PM 3/31/2003]
Old 03-31-2003, 08:20 PM
2.7(p/t)
sander's Avatar
Default Re: 11.5 compression and higher peeps, what octane fuel you running? (sslude)
with proper tuning you will be fine with 93 octane under 12:1 compression. engine mangament is a stock p73 (awaiting) (i personally have 11.6 in an lsvtec)
[Modified by jazzyfoo, 5:22 AM 4/1/2003]
Old 03-31-2003, 10:26 PM
Rob Dizzle's Avatar
Default Re: 11.5 compression and higher peeps, what octane fuel you running? (jazzyfoo)
b18c1 with gsr head, jdm itr pistons, flat faced valves, oem headgasket
im 11.5+ cr
I only have 91 octane in my area. with hondata i drove around untuned for over a month with no problems. and actually no knock sensor either
Old 04-01-2003, 05:27 AM
1 2 NV's Avatar
12.5:1, skunk2 chipped P28 92 octane.
Old 04-01-2003, 05:32 AM
Ruby Civic's Avatar
Default Re: 11.5 compression and higher peeps, what octane fuel you running? (hondaatwsu)
not that i doubt everybody, but you really don't know the extent of damage until you look at the internals...for example if you have no knock sensor how could you know there is no damaging predetonation? when you hear a knock or ping, the motor has already been gathering damage...no doubt the motor could be run for a while, but safe? not always clear plus we are yet to get hit with some hot weather in most of the country...
Old 04-01-2003, 06:04 AM
advanracing62's Avatar
Default Re: 11.5 compression and higher peeps, what octane fuel you running? (Ruby Civic)
91 oct. with 12.2:1 compression and JUN III cams in an ITR motor.
Old 04-01-2003, 06:54 AM
ej8
ej8's Avatar
Default Re: 11.5 compression and higher peeps, what octane fuel you running? (advanracing62)
92-93 octane 11.2:1 here, stock timing
Old 04-01-2003, 08:14 AM
turbodsmpower's Avatar
Default Re: 11.5 compression and higher peeps, what octane fuel you running? (ej8)
12.5:1 roller waves, skunk stg2 cams 93 octane here
Old 04-01-2003, 09:44 AM
dfoxengr's Avatar
12.5 street, hondata 93 oct
Old 04-01-2003, 09:47 AM
Katman's Avatar
I'm personally running around 11.5cr, a mugen chipped P08 ecu (disabled KS), and 91 octane.
No pinging issues at all.
[Modified by Katman, 10:47 AM 4/1/2003]
Old 04-01-2003, 09:52 AM
Kataku2K3's Avatar
Default Re: 11.5 compression and higher peeps, what octane fuel you running? (Katman)
11.5-12.0:1 you'll be fine with 92.... You can get away with up to ~13.0:1 on the same but the tuning margin is greatly decreased... Still no detonation... TUNING IS EVERYTHING but you should have absolutely NO problems with 11.5:1... Latez
Old 04-01-2003, 10:21 AM
New User
NSX Bob's Avatar
93 octane and hondata management. However, my Spec B's have enough overlap to reduce compression a bit, so I would guess this is running w/ about 12-12.1 cr.
Old 04-01-2003, 11:15 AM
RuKKus's Avatar
12+ compression running on 91 octane with chipped p28. It was untuned for 6 months and when I took it all apart everything was clean as hell.
Old 04-01-2003, 01:54 PM
google's Avatar
Default Re: 11.5 compression and higher peeps, what octane fuel you running? (RuKKus)
12:1 lude ... 93 oct sometimes 94 when i can make it to sunoco. make sure u timing is correct.
Old 04-01-2003, 07:46 PM
H22coupe's Avatar
Default Re: 11.5 compression and higher peeps, what octane fuel you running? (1320in11)
Thanks for all the replies. Good to see many set-ups running similar to what I'm working on running on pump gas.
Old 04-01-2003, 08:45 PM
vtec69's Avatar
a little higher than 12:1 ls/vtec and was running on 93 even before the car was tuned and ran perfect
-Brian
Old 04-01-2003, 10:00 PM
junya16's Avatar
Default Re: 11.5 compression and higher peeps, what octane fuel you running? (vtec69)
91 octane with 11:5:1 with the jun 3 cams on stock timing at the moment
Old 09-30-2004, 01:52 PM
jr_istheman's Avatar
Default Re: 11.5 compression and higher peeps, what octane fuel you running? (junya16)
93 octane on b20/vtec, 12.5 comp. ran 3 months untuned with little problems, now hondata tuned and it's been running great for the last 2 years.
unknown2
08-05-2006 04:41 AM
dohcMONSTER
18
01-26-2006 10:57 PM
teg your it
04-23-2005 02:06 PM
gsrvx
11-09-2002 11:04 AM
Quick Reply: 11.5 compression and higher peeps, what octane fuel you running?
