Suspension & Brakes Theory, alignment, spring rates....
why is my back lower than the front?
Old 08-24-2010, 09:02 PM
chueymuas's Avatar
Default why is my back lower than the front?
so like the title says, why is my back lower than the front?..the car is dropped on eibach sportlines, which suppose to be an even drop of 1.8 inches.. the springs are with tokcio blues and i have some blox lcas on
my car
cousins car..his sits evenly..and has same springs
Old 08-24-2010, 09:50 PM
buymesomedunks's Avatar
Default Re: why is my back lower than the front?
did you just install them? if so you need to let them settle for a bit. orrr you may have installed them backwards.
Old 08-25-2010, 11:07 AM
TunerN00b's Avatar
Springs don't settle.
Now, if the bushings weren't correctly clocked, then they can slowly shift over time, as the extra stress of being ran out of position stretches / tears them.
They both look equally level to me. The front fender opening is larger than the rear, and a level car will always have more gap up front.
Old 08-25-2010, 02:52 PM
eg2jr's Avatar
your cousin car is on a down hill street so his front end looks lower and your car rear end is on the drive way so your rear looks lower... ?
Old 08-25-2010, 03:09 PM
DC5krazy's Avatar
ur shocks might be going out
Old 08-25-2010, 09:18 PM
23LX23's Avatar
I have tokico blues with the tokico springs and i have the same problem... except my front seems to have stood the same size as the stock suspension... and my back fits right above the tire
Old 08-27-2010, 05:25 AM
Colin's Avatar
The age/condition of your shocks has ZERO effect on ride height. You could put a blown shock in place, with all fluid inside removed and it'll sit exactly the same height as a brand new out of the box shock.
I don't see a significant difference in height on those two cars. Between different locations and different wheels you can't judge from those pics, imo. And from my experience most lowering springs will lower the rear a bit more anyway. With such a front heavy car (FF) you usually want to lower the rear a bit more in an attempt to gain some front/rear weight balance.
Old 08-27-2010, 09:36 AM
Cynical 1's Avatar
x2. shocks do nothing for ride height.
also the rear wheel well opening is slightly smaller than the front, giving the illusion. look at a new 3 series bmw for another example.
AFAccord
04-30-2011 08:04 PM
power11
Suspension & Brakes
05-16-2007 07:54 PM
1989CivicSi
Suspension & Brakes
18
08-03-2006 03:11 PM
gofastgsr
08-08-2004 08:06 AM
globe
06-01-2003 09:41 PM
Quick Reply: why is my back lower than the front?
