Suspension & Brakes Theory, alignment, spring rates....
Thumping noise front wheel
Old 05-20-2010, 01:29 PM
chanelton's Avatar
Default Thumping noise front wheel
Hello,
drive a 2003 EP3 Civic. just changed my front rotors and pads (OEM) last week. Now developed some sort of thumping noise from the front end. The noise would get faster as the car moves faster. Noise remains the same if I turn rigtht or left. Once I apply the brakes the noise goes away completely.
what could this be? pad loose maybe?
Thanks!
Old 05-21-2010, 02:46 AM
BenjaminX2's Avatar
Default Re: Thumping noise front wheel
You could check the little metal plate that sits between the pad and the bracket. Not the plate between pad and calliper.
I had that problem last week, the metal plate shiftet towards the rotor. It is shaped like a "U".
Good luck
Dackonn
Suspension & Brakes
35
09-08-2021 02:54 AM
kcari
Suspension & Brakes
07-15-2010 04:01 PM
ch0baca
09-21-2009 01:31 PM
Lude Acts
01-24-2008 05:25 AM
Origin
08-29-2004 10:16 PM
Quick Reply: Thumping noise front wheel
