Suspension & Brakes Theory, alignment, spring rates....
Sway Bar Selection Help..
Old 04-23-2005, 11:08 PM
oc_civic's Avatar
Default Sway Bar Selection Help..
right now i have a 98 civic ex with
Tein SS coilovers
Omnipower Lower Control Arms
Skunk 2 Lower Tie Bar
and want to ad a sway bar i read a lot of stuff about people ripping out the whole bottom of the car, which obviously i do not want to do.. a friend of mine recomended the suspension techniques bar so what would i need to run something like that... would i need the beaks kit?
also all the people i read about ripping them out were using different oem honda bars (like the itr) does that have anything to do with it?
thanks in advance
Old 04-23-2005, 11:26 PM
idriveadelsol7's Avatar
Default Re: Sway Bar Selection Help.. (oc_civic)
anything above 19mm i would think you need subframe reinforcement... other than that, you're cool. beaks isn't a favorite here... comptech / a-spec racing has some pretty good stuff if you want a thicker bar along with some reinforcement.
Old 04-23-2005, 11:48 PM
oc_civic's Avatar
Default Re: Sway Bar Selection Help.. (deLasoL7)
so the beaks is pretty useless...? thats what i saw on another forum.. it looks like the suspension tech bar is right around 19... with that being the case what would you say... and wel beyond that without giving up my lower tie bar and havign to rebuy one what would you suggest for a sway bar that would work with what i have.. thanks for the help..
Old 04-23-2005, 11:53 PM
oc_civic's Avatar
what im looking for is minimal work, maximum safety, and greatest result.. lol so if i got that plate.. what would you suggest as a bar to go with it..
Old 04-24-2005, 12:24 AM
i think 19mm would be fine. anything over that is a little too much. as for the tie bar... i'm not to sure if you can use one with a aftermarket sway... somebody here can help you.
Old 04-24-2005, 07:11 AM
oc_civic's Avatar
im thinking that a spec racing plate and a 19-20 mm bar... have you ever heard of anyone breaking the subframe witht hat a spec racing plate? do you think that would be very reliable?
Old 04-24-2005, 09:33 AM
nice tie brace... comptech a-spec are good stuff.
Old 04-24-2005, 11:08 AM
fsufan814's Avatar
bump for answers to the questions at hand on what he should do, im very intrested also
Old 04-24-2005, 12:17 PM
Default Re: Sway Bar Selection Help.. (fsufan814)
if you're going above 19mm get the aspec or comptech rear sway/tie combo (no reports of torn subframes yet amongst those. beaks is weaksauce). i was going to slap on an integra-R rear sway on my del sol but then i would have to change my shocks, control arms... too much drama. just go 19mm it'll make your life easier.
Old 04-24-2005, 01:05 PM
.1type.'s Avatar
i run suspension techniques sway bar on my 98 civic coupe, love it. it comes with everything you need. just bolt it on..
Old 04-24-2005, 01:59 PM
oc_civic's Avatar
Default Re: Sway Bar Selection Help.. (1type)
do you have the plate or any typoe of reinforcement kit??
thanks again for all the info!
Old 04-24-2005, 06:53 PM
Help we my pennies
BLUE EH3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1type &raquo;</TD></TR><TR><TD CLASS="quote">i run suspension techniques sway bar on my 98 civic coupe, love it. it comes with everything you need. just bolt it on..</TD></TR></TABLE>drill?
Old 04-24-2005, 07:54 PM
dude... relax. your **** is not going to fall apart if you do not go over 19mm. read~! no tie brace until you go over 19mm. if you want to go over that, invest in the comptech or a-spec racing sway/tie combo.
Old 04-26-2005, 07:44 AM
oc_civic's Avatar
Default Re: Sway Bar Selection Help.. (idriveadelsol7)
do you guys think that i can run the ST bar and the aspec racing brace.. i think that is what i would like to do but im not sure it will fit..
Ek-Xang
02-04-2010 12:30 AM
SyDuck
08-19-2006 03:41 PM
revvin9k
08-05-2004 09:14 AM
JforJonathan
04-14-2004 11:52 AM
SloCivicHMM
12
05-19-2003 11:45 AM
Quick Reply: Sway Bar Selection Help..
