Suspension & Brakes Theory, alignment, spring rates....
New brake pads rubbing against rotor
Old 05-12-2012, 09:59 PM
Tenzo's Avatar
Default New brake pads rubbing against rotor
Okay, so I just changed my front brake pads on my EG and when I turn the wheel, I hear the rotor grinding against the new brake pads. I'm aware that they need to break-in or bed-in first after about 500 miles for the pads I got. (Some cheap Duralast ones, just temporary until I get all new rotors and better pads) My question is when I installed the pads, are they suppose to be touching the rotor? There was no real answer to this, so I assumed they just went on touching. Every tutorial or instruction I got for changing pads was that they just get slapped on and should start to settle in over time.
Old 05-13-2012, 07:59 AM
nealnanoHX's Avatar
Default Re: New brake pads rubbing against rotor
LMFAO really. Are brake pads supposed to touch the rotor!!!!?????? Yes that is how brakes work. You press the brake pedal which pushes brake fluid to the calipers, the calipers press the pad to the rotor and the car stops. Yes the noise should go away and it should be a very slight rubbing sound that will go away after a day or so. If not you did something wrong.
Old 05-13-2012, 08:53 AM
I serve phở for my babies
ohsnapzafingcu's Avatar
disk brakes always have contact with pad/rotor, drums do not.
Old 05-13-2012, 09:45 AM
FlewByU352's Avatar
When you turn the wheel you hear the rotor grinding... sounds like the dust shield and not the brake pads. I've never in my life heard my brakes grinding. I've heard squealing because racecar brakes but never grinding.
Old 05-13-2012, 10:05 AM
MonkeyMagic's Avatar
^that
op, you bent the dust shield when you changed the brakes. bend it back.
Old 05-13-2012, 10:24 AM
Tenzo's Avatar
Well obviously the pads are suppose to make contact when you brake lol. I'm asking if they're suppose to be touching when you install them. ohsnapzafingcu just answered the question, thanks. Lol cu...
I was thinking it was the dust shield, but I highly doubt it. I know I bent one of them when I was changing a wheel stud, but when I changed the other pad, I didn't even touch the dust shield. Then again, I'll consider it a possibility. If this may give a clue, when I press the brake, then let off, I hear what sounds like a click coming from my front driver side brake. Only happens sometimes. I have a feeling I messed up on the brakes.
Old 05-13-2012, 11:03 AM
The Grumpiest
grumblemarc's Avatar
Install the shims properly? Did you apply that red goop?
ndogg810
Honda Civic (2001 - 2005)
01-09-2007 07:10 PM
Sic_DA_Nine
12-02-2006 06:46 AM
faSHOwidIT
04-18-2005 02:06 AM
InTeGrA_bLazEd
10-14-2003 12:47 AM
B18CYAAA
10-01-2003 08:18 PM
Quick Reply: New brake pads rubbing against rotor
