Suspension & Brakes Theory, alignment, spring rates....
how to remove a "ring" in the knuckle and ball joint
Old 12-19-2005, 12:10 PM
airsodam's Avatar
Default how to remove a "ring" in the knuckle and ball joint
Hi~
I am replacing a front lower ball joint for seveal days..
having had a lot a troubles and finally got to the point where i can pull the ball joint out but!! there is a "Ring"
that blocks the way of the ball joint..
My Q is how to remove the "Ring"
Thanks
Old 12-19-2005, 02:29 PM
chrisw85's Avatar
use a snap ring plier, or use a couple screwdrivers and pliers and a buddy to help. I like the snap ring pliers better.
Old 12-19-2005, 06:16 PM
mrlegoman's Avatar
Default Re: (chrisw85)
Make sure to wear eye protection!
Old 12-19-2005, 11:50 PM
airsodam's Avatar
Default Re: (mrlegoman)
haaa~i got it out accidently with a flat head driver^^
Thanks a lot for that tho.!!
Adam_F123
06-20-2005 04:36 PM
ultraforce77
07-15-2004 02:59 PM
civcexcoupeblack
12
09-22-2002 02:27 AM
Flamenco-T
08-21-2002 11:49 PM
Quick Reply: how to remove a "ring" in the knuckle and ball joint
