How To: Brake Line Tuck Guidelines..
#1101
1 Post
Re: How To: Brake Line Tuck Guidelines..
Anyone know where I can get new oem brake tube fittings. I have 30 ft roll of 3/16 line for my tuck but want fresh oem fittings. Any links to these. Stainless steel would be even better.
#1104
I'm having only one issue with doing this. I am using the oem 3/16" line and need to "T" off the master cylinder. What fitting's do I need to properly "T" into the factory lines? I am having issues figure this out prob due to this all being new to me?
#1106
The master cylinder has one port. But I need to "T" into two lines. One for the drivers side and one for the passengers side. No prop valve.
#1107
No rear brakes? You just need a pretty standard -3 t fitting. I prefer steel for brake lines.
General question: I'm in the market for a new flare tool. Which o the Ridgid ones do you folks recommend?
https://www.ridgid.com/us/en/flaring-tools
#1108
Rear brakes will work only off hydraulic assisted staging brake. So I will "t" off that as well to run each line for the rears.
#1109
I'm just needing to know where I can find them and specs. Because I'm using the oem fitting's on the lines I have a bucket full from cars I've scrapped. So the "t" must allow them to thread into it.
#1110
So you just need to dig through your box o' parts, pick your fittings, and then order a t-fitting with the thread of your choosing. The factory flare angle is 45*
Something like this:
which can be found almost anywhere. Summit/Jegs/an-plumbing.com/pegasus/etc...
#1112
The hardlines I will be using are 3/16. The thread for the fitting's are 10X1.0mm and from what I have been reading the flare is 37 double flare?
#1114
Ok guys here is my noob question after reading thru the pages I couldn't find my answer. I recently did a full disk conversion on my 93 ex coupe, my buddy with a Del sol sold me his whole setup spindles and all, I know I need to change out my current prop valve which I acquired on from a DC2 Integra but I was told that in order for the DC2 prop valve to work I will have to rebend my stock lines is this tru? and are these lines any good http://shop.advanceautoparts.com/p/a...rm=brake+lines.
#1116
is there any way we can get the pic on page to work? I understand that the OG poster is no longer on here longer..
#1118
Thx Adam....
Also I just received my brake-tuck kit and I was wonder what size drill bit are we using to drill the hole for the bulk heads.
#1120
Does anyone on here have a list of all the fittings for the brake line tuck on a Honda del sol? I've been looking, saw one listed on a for sale. Wanted to tackle on a budgeted DIY... PM me THANKS!!!
#1121
3/16 steel or stainless line
3an Nut Ends x1pack
3 An bulkhed fittings x4pcs
3an Line sleeves x 2packs
Bender
get a good deburr tool as well as a good bender... brakeline tuck under 60$ with the bender plus however much line you may need.
#1123
Anyone know length for banjo bolts for a S2000 brake master cylinder? I need to know which ones to get to convert to banjo fittings.
Corksil
46
01-21-2012 07:44 PM
Soda Popinski
12-31-2005 12:28 PM
