Suspension & Brakes Theory, alignment, spring rates....
Coilover Spring Replacment
Old 12-21-2011, 01:48 AM
DawgC2's Avatar
Default Coilover Spring Replacment
I just got a set of Cusco Zero 1 for my DC2. thinking to get new springs with higher spring rate, Front 12k/ Rear 10k. my question is what spring length should I get? 8" length or 9" length??
Old 12-21-2011, 10:29 AM
Somalie187's Avatar
Default Re: Coilover Spring Replacment
First question you should ask is if those Dampers will be able to handle those spring rates.?.
As far as spring length goes, I believe 8" is the usual.
Are the coilovers separate preload and height adjustment? Did you get a good deal on them?
Old 12-21-2011, 01:42 PM
DawgC2's Avatar
Currently they are front 9k/ and Rear 6K. 5 way adjustable and height adjustable. I got them for a good price. Do you know if cusco Zero1 can handle 12K/8K???
Old 12-21-2011, 01:44 PM
The Grumpiest
grumblemarc's Avatar
Maybe you should contact Cusco?
http://cusco.co.jp/en/about_us/contact/
Old 12-23-2011, 10:04 AM
ksport's Avatar
most coilovers you can go -/+ 2kg from the standard rates they give you.
But for sure call Cusco to confirm, ask for Stephen he can get you taken care of!
jdmhatch1
Suspension & Brakes
17
02-27-2009 06:54 AM
speedminded
10-21-2004 06:44 PM
civickidd99
08-13-2003 07:11 PM
Quick Reply: Coilover Spring Replacment
