aftermarket wheel bearings
It's time to replace my front passenger wheel bearing.
I'm using EF9 knuckles that require DA9/DB1 wheel bearings.
New wheel bearing from acura costs $115.
Found some Koyo wheel bearings for half the price.
Are aftermarket wheel bearings quality replacements? or Should i go with oem?
Just trying to do this right the 1st time. Thank You
#1 Super Guy
Re: aftermarket wheel bearings (eda6)
Here is a good deal on the part directly from an Acura dealership...
http://www.acuraautomotivepart...y.jsp
Re: aftermarket wheel bearings (94eg!)
Thanks for the link.
Can I use a ball joint press to install the new wheel bearing? If not, do you know of a good shop in the las vegas area with a press?
#1 Super Guy
This is the only place I've found that would press bushings out/in for me. The charge $10 a bushing to remove/replace, so it should cost about the same if you could get the hub off. If not they may charge you more...
Charleston atuo parts
Scott53092
03-23-2011 07:30 AM
