Southern California Fresno & Below
Looking for a machine shop in hesperia applevalley victorville high desert area.
Old 03-13-2011, 08:42 PM
No-Traction = Fun
CaliforniaDad's Avatar
Default Looking for a machine shop in hesperia applevalley victorville high desert area.
hey all you high desert rats. I'm looking for a good machine shop up here in the hesperia applevalley or victorville area.
I'm going to rebuild a B18C1 I picked up.
I need to do the following,
Head:
-pressure tested
-cleaned out
-3 angle valve job
-new valve seals
-and resurface
block:
-Hot Tank
-Hone all Cylinders
-Deck'd
-crank micropolished
Old 03-14-2011, 11:15 AM
No-Traction = Fun
Default Re: Looking for a machine shop in hesperia applevalley victorville high desert area.
anyone? anyone?
Old 03-14-2011, 11:59 AM
No-Traction = Fun
I pulled the pistons and rods out of the bottom end and cleaned them up. They look like there in great condition and I was wondering if I can/should reuse them. The block was a 2001 not sure how many miles. It had a bad rod bearing.
Old 03-17-2011, 04:25 PM
No-Traction = Fun
Found a local shop and was told the rods need to be cut and re-sized back to spec. $20.00 each
Old 05-30-2011, 03:50 PM
Smex26's Avatar
Hey, How much did they charge to rebuild your bottom end? Where is the shop located at bro? and What was done to it and how much did they charge.... i need a shop.... Thanx bro.
Old 05-30-2011, 08:47 PM
robcivic559's Avatar
i live around the same area would like too know 2 got a 90 LS da block and 94LS block
760 HI DES
Old 06-08-2011, 09:21 PM
No-Traction = Fun
Arringdale's Engine Rebuilding
11918 I Avenue
Hesperia, CA 92345-4945
(760) 948-5155
Ask for Rick & tell them David G sent you!!!
Old 06-09-2011, 03:57 AM
Daisy... Daisy...
Dogginator's Avatar
This will probably help more people in the regional forum.
Old 06-09-2011, 10:33 PM
SP GARAGE's Avatar
i know of 2 great engine builders in that area.... PM me... and i can help you get in contact with them... theres jeff from GO-PWR and LEO G. from LGwerkz
Old 12-11-2015, 07:10 AM
strategy400's Avatar
I've used Arringdales with great results. 100k on my D15B7 and still going strong. I plan to be a repeat customer.
Zor_Primo
South
02-23-2011 08:55 PM
densetsu
12-13-2006 05:32 PM
DefiantGSR
18
01-29-2005 11:43 PM
DefiantGSR
01-25-2005 08:44 PM
98civicEX
11-05-2002 05:57 PM
Quick Reply: Looking for a machine shop in hesperia applevalley victorville high desert area.
