B18B1 Too B20B
Old 02-12-2017, 08:56 PM
AnHeL need help's Avatar
Default B18B1 Too B20B
So i just finished my swap from a B18B1 to a B20B i have a 1995 acura integra ... my car is having trouble turning on ? I dont know what it is .. it has gas it has oil i just changed spark plugs got a new battery an everything seems fine my lights work my engine trys to turn on but still nothing ... i dont know whats going on it cranks up i need advice guys please anyone just really wanna start the car now ..?
Old 02-14-2017, 08:17 AM
Fish Twig
tony_2018's Avatar
Default Re: B18B1 Too B20B
Distributor connected?
Ecu connected?
Did you remove the distributor?
Did you re-align the distributor?
Did you replace the timing belt?
Did you re-align the tming belt?
Are your spark plugs wire connected properly?
Old 02-17-2017, 12:37 AM
The Rs's Avatar
Check your grounds. Make sure that the one that connects to the valve cover is not connected to the part that covers the timing belt. It should look like the picture below. Good luck.
The Rs
Old 02-17-2017, 07:46 AM
Fish Twig
tony_2018's Avatar
Actually the car can still run w/o that ground, I accidentally had this happen when I did a valve lash. Weird but after shutting off the car I did put it back though.
Old 02-17-2017, 08:05 AM
The Rs's Avatar
It CAN still run, but this ground CAN also cause start issues and I thought it pertinent to mention the one that is sometimes connected the wrong way. I just finished my swap and was having the same issue as OP. After installing the ground the proper way, it started right up. Good luck.
The Rs
Old 02-17-2017, 03:51 PM
Fish Twig
tony_2018's Avatar
You catch that transmission ground wire?
Ok back to OP, waiting for his response
96delsol123
28
03-30-2013 08:51 PM
hatchyboy89
10
07-17-2012 02:19 PM
streetlights
11-08-2011 02:07 PM
DetroitPOScivic
37
06-10-2004 08:07 AM
Genedog
05-25-2004 08:57 AM
Quick Reply: B18B1 Too B20B
