Can you use a vinyl cutting machine to make a graphics overlay for painting?
Old 06-22-2012, 09:36 AM
pityocamptes's Avatar
Default Can you use a vinyl cutting machine to make a graphics overlay for painting?
Basically what I need is something to cut out a detailed design that is basically a sheet that has a sticky side. Apply the cut out design with the sticky back on the metal and then start pulling off cut segments of the design for different colors. Would a vinyl cutting machine work, if so what type of sticker material would work? If not any suggestions? Thanks!!!
Old 06-23-2012, 06:50 AM
Skalabala's Avatar
Default Re: Can you use a vinyl cutting machine to make a graphics overlay for painting?
Yes it will work. Do you want to remove the complete sticker on the end of the day?
Any thin vinyl sticker will work.
And how big is the job area?
Go to your local decal place and ask for some help
Old 06-26-2012, 02:33 PM
HFJ0kr226's Avatar
Well if you wanna do it right, you need to find a good source of vinyl cuz not all vinyls tend to stick well. And don't get the one that has massive adhesive on it cuz then it will be hard to take off or leave glue one the car paint. If ur design has to much detail in it, make sure the small pieces of vinyl stick well, or paint will seep under the vinly and ruin it. Decal shops are a good source, but they charge a lot for a small piece of vinyl, try to go to a local sign and paint supply shop, the sell the yard of vinyl cheaper. And all sorts of and adhesive mount type. That way you wont have any trouble paint or designing it. i design my on stickers.... good luck with your process
bboyoracle
Mid-Atlantic
19
08-22-2014 09:35 AM
Eyger
Paint and Body
01-04-2011 08:48 PM
szczerbanator
Northwest
31
01-03-2010 11:30 PM
DANgerous
04-03-2004 09:50 PM
sjteg
05-13-2003 10:48 AM
Quick Reply: Can you use a vinyl cutting machine to make a graphics overlay for painting?
