Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2004 Pilot Door ajar light won't go off
Old 10-06-2016, 05:51 PM
Kathyle3's Avatar
Default 2004 Pilot Door ajar light won't go off
The door ajar light is indicating that my front passenger door is not shut, when it actually is. I replaced the door switch but unfortunately that didn't solve my problem. I haven't noticed any other electrical issues that would suggest it is a fuse problem. Any ideas for what might be going on here? Thanks for your help!
Old 10-07-2016, 06:15 PM
Global Moderator
tech8's Avatar
Default Re: 2004 Pilot Door ajar light won't go off
Possible culprits:
  • The green wire going to the front passenger door switch is shorting to ground; for example, wire or insulation has a cut and wire is touching the car's metal chassis.
  • Faulty "Failure Display Circuit" which is built into the gauge assembly (aka instrument cluster). If it was faulty, the gauge assembly may need replacement.
Try this, disconnect the green wire going to the front passenger door switch. Tape it, so that it doesn't fall into the hole/opening where the switch is. Then close that door, does it still show the door ajar?
Old 10-23-2016, 06:21 PM
TyGuy88's Avatar
I have seen a few cars that have had something (usually the seat belt) closed in the door causing a dent where the door switch contacts the door. It won't push the plunger of the switch in enough for it to recognize that the door is really closed. You can try manually pressing the plunger in with the key on to see if the warning light goes off and check for a dent in the metal of the door.
afnan
19
07-09-2021 09:28 AM
GarySeven123
02-16-2013 05:21 AM
lovemyintegra1
07-16-2007 11:47 PM
Silent_Destruct
11-26-2006 07:02 PM
Chiller20
12-26-2002 06:29 PM
Quick Reply: 2004 Pilot Door ajar light won't go off
