Problem w/ door sensor
Old Dec 26, 2002 | 05:47 PM
Chiller20's Avatar
Default Problem w/ door sensor
Does anyone know what can be causing this? When the ignition is on and you open the passanger door, the car detects that the door is open. But when the ignition is off and you open the passanger door, the car does not detect that the door has opened. The driverside door is fine. I tried switching the switch but the same problem persists. Any suggestions in what to look for?
Old Dec 26, 2002 | 06:13 PM
JPP's Avatar
JPP
Default Re: Problem w/ door sensor (Chiller20)
What do you mean by " car don't detect the open door" ? Does the ceiling light turns on when opening the passenger door with ignition off? If so everything is OK
Old Dec 26, 2002 | 06:15 PM
Chiller20's Avatar
Default Re: Problem w/ door sensor (JPP)
No, the interior light does not turn on, but when I open the driverside door it turns on. Weird
Old Dec 26, 2002 | 06:24 PM
JPP's Avatar
JPP
Could be a ground wire problem on the passenger side door switch. I have a similar problem with the trunk light, if I play with the trunk latch handle a few times it finally makes contact and the light come on...the ground wire is at fault when I test it for continuaty
Old Dec 26, 2002 | 06:29 PM
Chiller20's Avatar
The ground for the door switch is the screw that holds it in place touching the body of the car, correct? How would I go about troubleshooting this and if so, correcting it?
afnan
19
Jul 9, 2021 09:28 AM
Kathyle3
Oct 23, 2016 06:21 PM
GarySeven123
Feb 16, 2013 05:21 AM
lovemyintegra1
Jul 16, 2007 11:47 PM
Silent_Destruct
Nov 26, 2006 07:02 PM
