Lighting HID/Xenon kits, Retrofits and Associated Topics
Wiring pnp eBay hid kit to use as hi beams in a retro
Old 03-09-2009, 04:21 PM
djslim23's Avatar
Default Wiring pnp eBay hid kit to use as hi beams in a retro
Soo I wan't to do a retro on my 99 civic, but I definitely do not want to lose my high beams. I was just curious about how difficult the wiring job would be. The PnP HID kit I have has a bi-xenon H4 bulb. I also have a scrapped eBay sh!tty "halo projector" housing which I have found a way to get the h4 bulb in (in the high beam reflector). I have the orignal H1 brights from the eBay housing with the 3-prong connector attached, so I'm assuming that's what I'd have to hack into. Thanks, and let me know if you'll need any pictures.
Old 03-10-2009, 02:19 PM
Master Detailer
98civdx's Avatar
Default Re: Wiring pnp eBay hid kit to use as hi beams in a retro
if your doing a retro fit your h4 bulbs will not work.
Old 03-10-2009, 04:29 PM
djslim23's Avatar
Right, I'm aware that I would need to get some D2s bulbs. In doing some research I have found a better option: using my eBay ballasts for now and using a harness to connect to the D2s'. I suppose my real question now is if OEM projectors such as the TSX's are a direct or close to direct fit to the eBay halogen projector housing.
Old 03-10-2009, 05:29 PM
Master Detailer
98civdx's Avatar
yea theyll fit, you will have to custom mount them of corse.
Old 03-10-2009, 05:38 PM
djslim23's Avatar
Yeah I figured...
Would it be more or less of a hassle than using the OEM Civic headlights?
I figured it would be less, plus the Hi-beams are already there. Thanks.
Old 03-10-2009, 09:56 PM
Master Detailer
98civdx's Avatar
youd be better useing oem lights
with the halos the space to put them is going to very small and tight, oems youll have space around them, i would recomend tl projects tho,
what do you mean high beams are already there? civics use 1 light for high low,
if you use tsx you will only have low, tls will give you the high low beam you want.
Old 03-12-2009, 11:15 AM
djslim23's Avatar
Well I would be ditching the halos and I'd modify the plastic piece which they were mounted on. The eBay housing has a halogen projector and a high beam reflector, so that's what I meant by the high beams are already there. Do you think that setup (tsx's and halogen brights) wouldn't be better than using TL projectors in the OEM housing? Btw, my left housing got cracked when by someone in a parking lot so I'd have to add that to my expenses on the retro. Thanks.
Old 03-14-2009, 04:21 PM
Master Detailer
98civdx's Avatar
if you retro fit them you will not be able to have halogen highs, just low beam thats why i said tl. tsxs have seperate projectors for high and low beam, civics do not.
yes i think tls would be better or some other sort of bi xenon projector.
just my 2 sents but i would pick up some of thoses cheep *** ebay black hosings and then retro fit those.
tl projects with zkw lenses are GREAT.
Old 03-15-2009, 06:09 PM
djslim23's Avatar
Yeah I know that bout the lights, if you read my first post you'd see that I have a pair of eBay "projector" housings already I am gonna use which have the halogen projectors and the brights. I just ordered my parts so when I'm done I can post pics
Old 03-15-2009, 06:45 PM
striker_18's Avatar
But it's so easy to do it.
Old 03-15-2009, 07:26 PM
djslim23's Avatar
The wiring? or using the eBay lights?
And if you're sayin it so easy....is that bad ?
And Re my initial question...I'm not considering doing the PnP in my brights anymore cause I ran out of cash to get to ballasts, but to wire the high beams in you just shove its prong into the three prong connector? Do you have to have both connectors connected for them to work? because I tried plugging in my old lights, off the ebay housing, into one of the plugs and no deuce.
Old 03-15-2009, 07:52 PM
striker_18's Avatar
it's easy to do both.
the wiring is really simple too.
ballasts need a few secs to warm up so having HID's for your hi beams is, and I'm sorry to say this, retarded. Don't fall into that category.
your car shares a single negative. So, you're going to have to share the negative wire with both your hi beams and low beams.
You need a diode in there though from your positive hi beam to your positive low beam. Your car shuts off the low beam once the hi-beams have been activated. So, with a diode, the low beams won't shut off but rather there will be an open current to your low beams.
Old 03-15-2009, 08:31 PM
djslim23's Avatar
Alright thanks, that's exactly what I was looking for.
Old 04-02-2009, 09:13 PM
19Accord97's Avatar
I wouldn't recommend HID's for your brights. Ballasts do not like be turned on and off constantly. However, the life will depend on the amount of on/off cycles.
Old 04-03-2009, 04:49 PM
Master Detailer
98civdx's Avatar
if you life out in the country the for sure hid high beams but if not there really is no poiny like 19Accord97 said they dont like being turned off and on
Old 04-13-2009, 09:17 AM
djslim23's Avatar
Yeah I saw that too, I'm not going that way anymore. I do live in the country but it would still be impractical. I'm just using a pnp-d2s harness so I can just use my eBay ballasts for the retro. Hopefully they'll last until I get some cash.
avotegra
03-06-2008 12:47 AM
bopbop93030
Lighting
02-04-2008 11:27 PM
rluder21
03-01-2005 09:38 PM
EJ8 GSR-T
01-12-2005 07:28 AM
Quick Reply: Wiring pnp eBay hid kit to use as hi beams in a retro
