Lighting HID/Xenon kits, Retrofits and Associated Topics
Retrofit using OEM EG headlights?
Old 05-02-2013, 07:41 PM
Zaraki's Avatar
Default Retrofit using OEM EG headlights?
I've been on theretrofitsource about to order the Mini stage 3 kit.
However, I'm undecided on what headlight housings to use.
I'm pretty fond of the OEM look and fitment.
How would this affect the light output?
Old 05-03-2013, 04:28 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Retrofit using OEM EG headlights?
Wondering why you just don't make a call to the theretrofitsource?
Old 05-03-2013, 06:23 AM
spAdam's Avatar
User Donut. did a retrofit on the oem jdm lights back in the day (before all of the mini's were available). Looked great imo, no idea how well they worked though. Probably still much better than plug and play or even first gen HID's that still used sealed beam lenses.
Old 05-03-2013, 01:37 PM
Zaraki's Avatar
Quit being grumpy Marc.
I'm asking this here because I'm sure someone has done a retrofit using the oem fluted lense from a 92-95 civic.
Old 05-03-2013, 01:42 PM
Zaraki's Avatar
I've seen Donuts car and love that look.
I'd like to know how well they performed.
I know that when doing a retrofit, it's ideal to use a clear (non fluted) lense for the best light
dispersement. But I hate the way it looks.
Old 05-03-2013, 02:39 PM
spAdam's Avatar
Same here. All of the aftermarket lights for 5th gens are terrible.
Old 05-04-2013, 03:52 PM
tommi's Avatar
just use depo headlights and you wont have the fluted glass problem? or depo lenses on the oem housings?
Old 05-05-2013, 07:04 AM
spAdam's Avatar
Old 05-05-2013, 12:10 PM
Zaraki's Avatar
I'm leaning toward doing the retrofit with my OEM headlights.
It's not like the light output could be any worse than the stock BS I'm dealing with now.
Old 05-05-2013, 07:54 PM
jahong16's Avatar
the cutoff and output isn't going to be as sharp with flute compared to clear. i also am gonna retrofit with oem headlights because i care about the fitment more. but i either plan on buying ebay clear glass headlights and using the lens or get depos, but those have plastic lens. would like to see pictures if you retrofit oem fluted headlights.
Old 05-05-2013, 07:56 PM
m_shake's Avatar
Maybe shave out the flutes like this http://www.hondatuningmagazine.com/t...n/viewall.html though I believe usdm headlights are glass, wood need jdm plastic.
Old 05-05-2013, 11:16 PM
jahong16's Avatar
interesting, didnt know you could do that, problem solved
Old 05-06-2013, 06:47 AM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
I went with denji's. You can find them for 200 bucks new from denji off eBay. Like mentioned the flutes will cause problems but I have heard of people sanding the USDM glass lens smooth...
Old 05-06-2013, 08:54 AM
jahong16's Avatar
Did you go with denji version 1 or version 2 headlights?
Old 05-08-2013, 12:30 PM
Version 1
H0nda_Crazy
02-17-2013 10:13 PM
AlwayzSpoolin
Southeast (Sales)
12-25-2010 11:08 AM
BrayzieEF9
Lighting
01-17-2010 08:30 PM
SHO-NUFF
17
01-02-2007 05:33 PM
invisible
30
12-09-2006 07:34 PM
Quick Reply: Retrofit using OEM EG headlights?
