Lighting HID/Xenon kits, Retrofits and Associated Topics
2001 integra parking light issue
Old 03-22-2015, 02:00 PM
98dxkoupe's Avatar
Default 2001 integra parking light issue
I'm having an issue with my passenger side parking light although the blinker does work but no parking light. Could this issue be a fuse or a short in a wire somewhere anyone else have this issue before? Thanks
Old 03-24-2015, 03:19 AM
98dxkoupe's Avatar
Default Re: 2001 integra parking light issue
Anyone?
Old 03-24-2015, 08:12 PM
LowTEC SaiMike's Avatar
This is happening to the 1157 that is on the turn signal correct ?
Old 03-25-2015, 03:59 PM
98dxkoupe's Avatar
Yes the parking light and turn signal i believe is same bulb my turn signal works but no parking light on passenger side.
Old 04-18-2015, 09:18 PM
98dxkoupe's Avatar
Any help?
Old 04-19-2015, 10:31 AM
the 1157 is a dual filimant bulb . is both filimants not broken . Also , i think there is an 194 bulb as well . check both and see if the bulbs are broken
Old 04-20-2015, 01:27 AM
98dxkoupe's Avatar
Bulbs are not broken first thing i replaced was the bulbs and still no passenger parking light i checked fuses and there good not sure whats going on
Old 05-08-2015, 04:39 PM
98dxkoupe's Avatar
Anyone have a similar issue? Its driving me nuts!
Old 05-12-2015, 02:55 PM
skillzx201's Avatar
you should check to see if the bulb holder is corroded.
Old 05-12-2015, 03:55 PM
98dxkoupe's Avatar
I tried replacing the socket and still does the thing. Any help would be appreciated.
Old 05-26-2015, 04:51 PM
98dxkoupe's Avatar
Bump still need help driving me insane having one parking light on! Replaced socket and still no parking light could there be a short somewhere?
Old 05-27-2015, 06:08 PM
Hawaiianhonda's Avatar
For some dumb reason I'm having the same issue, passenger side running light doesn't work, I have a JDM front end thou but my headlights work but the fog and city light don't work
Old 06-01-2015, 01:04 AM
98dxkoupe's Avatar
Its literally driving me crazy gonna see if i can trace the wires out
Old 06-29-2015, 04:51 PM
98dxkoupe's Avatar
Bump anyone have this problem? Socket that i replaced was burned not sure if that means theres a short or a blown fuse?
Old 10-11-2015, 07:16 PM
98dxkoupe's Avatar
Bump still can't figure this out passenger turn signal works but no parking light!!!
Old 10-12-2015, 05:33 AM
rollinmyda's Avatar
I'm having the exact same issue on my civic. I have swapped bulb, socket, and probed the wire with a DMM. In my case I'm not getting voltage out of the fuse box on that wire so replacing the fuse box is my next step. Have you tried tracing the wire back through the harness and checking for continuity and voltage at each connection?
98dxkoupe
05-18-2015 01:54 AM
Jimmy92Accord
07-23-2008 09:51 PM
rayccfhk
01-17-2008 01:28 PM
Metal Typhoon
10-17-2006 05:14 PM
niteboyzzz
10-04-2002 11:24 PM
Quick Reply: 2001 integra parking light issue
